20 Most Recent
Dynex Docking Station with Remote for Apple iPod Questions & Answers
Cassete adapter for Ipod nano wont work in the
If you're using a cassette adapter it doesn't need to be set to a radio station your truck should be set to tape input. However you could get a 12V lighter FM transmitter that will play the iPod over the radio and with that you'd need the radio set to a specific station.
My screen will not turn on even tho there is power?
Just repaired this TV today. You will need to purchase the inverter board. The TV will power up....you will see "PLEASES WAIT", and disappear, you have a black screen. When you remove the back cover, look to your left. You will see a long vertical board. That is the board you will replace. Seek shop jimmy, enter model number of your TV. You will see an inverter board for $24.95 plus $9.50 shipping. Thanks for asking me, Matt of Martins TV Repair.
We cannot get the sound
I think this is the model, or close to it.
http://downloadcenter.samsung.com/content/UM/201009/20100906145211281/[UC5000-ZA]BN68-02625A-03Eng-0903.pdf
Page 11 talks about audio out.
The actual model of the Dynex would be useful.
Maybe you could get it to come from the actual audio source, like the Cable Box, which has really good audio options while TV's usually don't and add nothing to the sound by being in the loop.
Tried to use mic, only picking up computer sounds.
Ensure that you have selected the Microphone or the Line-in as your recording input. It sounds like you have set STEREO MIX as the recording input. Double click your speaker, select from the drop down "Properties" then Adjust volume for (RECORDING) select that and ensure that your appropriate recording device is selected. (XP)
How do I change to degree mode on my porpo YH-2000
- Power Off: Turn off the device.
- Jumper Configuration: Locate the jumper labeled "S16" on the device. Initially, it should be connected to pins 2 and 3.
- Power On (Alarm+All LEDs Flashing): Turn the device back on. You'll see the alarm LED and all other LEDs flashing.
- Power Off Again: Turn off the device once more.
- Jumper Adjustment: Change the jumper configuration from pins 2 and 3 to pins 1 and 2.
- Finished: Your Porpo YH-2000 is now set to the desired angular unit mode.
If you encounter any issues, you can press the reset switch on the back of the device to reinitialize it.
