20 Most Recent
LG 1.5 Cu. Ft. Full-Size Microwave - Black Questions & Answers
Microwave shuts off as soon
Hi
Thanks for using FixYa. This most commonly is a bad
door switch, other possible problems are a faulty relay or solder joint on
the power module, but a bad door switch is most common. Also make sure you hear the
fan is still operating in your microwave. Next is to make sure the air intake
grill on your microwave is not plugged up with air borne dust and dirt.
Please do accept the solution
if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Won't cook.
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
My new LG solardome MA3884vc overheats melamine plate @30 seconds
If your LG Solardome microwave oven is overheating a melamine plate within 30 seconds, there could be a few potential issues at play:
- Power Settings: Check to see if the power settings on your microwave are too high. If it's set to a high power level, it can cause certain materials, like melamine, to overheat quickly. Try reducing the power level and see if that helps.
- Plate Material: Melamine plates are not suitable for use in microwave ovens as they can overheat and potentially release harmful chemicals into your food. It's recommended to use microwave-safe dishes made of glass, ceramic, or microwave-safe plastic.
- Microwave Performance: If the microwave is consistently overheating items within such a short time frame, it might indicate a malfunction. In this case, it's best to contact LG customer support or a certified technician to inspect and repair the microwave.
- Placement and Usage: Ensure that the plate is placed centrally on the turntable and not touching the sides of the microwave. Also, avoid using the microwave for extended periods without interruption, as this can cause overheating.
- Testing with Different Materials: Try using a microwave-safe ceramic or glass plate to see if the issue persists. If other materials heat up quickly as well, it could indicate a problem with the microwave itself.
How to remove door COVER from door of LG Microwave model LMHM2017ST
Here are the steps to remove the door cover from the door of your LG Microwave model LMHM2017ST:
- Unplug the microwave from the power source.
- Open the microwave door and locate the four screws on the inner edge of the door.
- Use a Phillips screwdriver to remove the four screws.
- Carefully separate the outer door panel from the inner door panel.
- You will now see the door cover attached to the outer door panel.
- Use a flathead screwdriver or plastic pry tool to gently pry the door cover off of the outer door panel. Start at one corner and work your way around the edge.
- Once the door cover is removed, you can replace it with the brushed silver cover from the new door.
- To reassemble the door, simply snap the new cover onto the outer door panel and then reattach the outer door panel to the inner door panel using the four screws you removed earlier.
Make sure to be careful when removing the door cover, as it can be fragile and may break if handled roughly.
LG microwave door open pad broke.
Question edited for clarity.
Question moved from Building Materials to LG Microwave.
Take into an LG Service centre for repair. They are sealed by security screws and are dangerous inside. You won't be able to get parts.. If it is a counter top microwave and cost $60, just buy a new one as they are a disposable item.
