20 Most Recent GE Profile 22.2 Cu. Ft. Bottom-Mount Refrigerator - Stainless-Steel Questions & Answers
How do i remove back panel inside the freezer on a ge profile
I am guess the "-" is really a "a" as you listed in your model#. This is actually built by LG and stamped GE on the front. So there are two ways you can do this.. The first is to remove the door from the rails, then all the racks, then the rack guides,then the icemaker, then the back wall, then you can use hot water to melt the ice out of the trough (do not use a heat gun because the plastic liner will melt quite easily and be very careful as everything is pretty sharp behind there) The easier way is to take off the back panel (you would have to do this anyway) and make sure the little black flapper on the bottom of the drain is not all gummed up with lint,pet fur,ect.. Then defrost the unit for 24 hours, unplugged and doors open. Of course you will need to move your food but your finger,back and knees will thank you! These tend to clog here anyway and digging the ice out from the inside is a severe pain! Do not cheat the 24 hours and leave the doors open! g7090609-00002-n1dvgax2is1j2ueeyj0buc1k-1-0.png
2/12/2018 10:38:02 PM • GE Profile 22.2... • Answered on Feb 12, 2018
My refrigerator is not cooling
needs Freon I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_a3369546f8067589
4/17/2017 6:52:11 PM • GE Profile 22.2... • Answered on Apr 17, 2017
I have water under the vegetable tray. I believe
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the inside of the freezer at the bottom of the rear cover.
8/19/2014 2:12:45 PM • GE Profile 22.2... • Answered on Aug 19, 2014
0answers
Tdc18paaaww leaking ice buildup
Is this auto-defrost model? Usually, heating element that defrosts the ice in back of freezer can go bad. How old is the model?
1/10/2014 3:41:16 PM • GE Profile 22.2... • Answered on Jan 10, 2014
My refrigerator temperature is high and my freezer temp is low
The first thing you want to do is open the freezer and see if the fan inside there is running. The reason is the freezer cools the refrigerator side by circulating air from the freezer. If the fan is running then your problem is one or more parts of the defrost system is malfunctioned and in return your problem arises. There are three parts to the system, the defrost timer or in some cases control board, defrost thermostat also known as a bi-metal, and the defrost heater. The defrost system is set up to operate as so. The defrost timer or control board will turn the machine off, in some cases every 8 hours, some 12. During this time period the defrost heaters, located behind the freezer wall and rest underneath the evaporator, yet wires to them run up the side of it, are energized and emit heat that raises upward to melt the ice that has formed on the evaporator coils. The bi-metal or defrost thermostat is at the top of the evaporator. When the heat from the heater starts to reach the bi-metal, it breaks the circuit turning the heater off. The whole purpose of this is because the freezer cool the refridgerator side by drawing air across the coils and blowing to the other side via the evap fan motor. In my opinion, if you change one part of the defrost system change them all because usually when one part fails another will follow, so save yourself the time and the food loss, the cost difference is minute. If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
6/22/2012 11:14:32 PM • GE Profile 22.2... • Answered on Jun 22, 2012
My refrigerator icemaker not workingtech told me i
If you are getting water, then usually it is a temp sensor under the panel in the freezer. The sensor is a cut & replace. That has worked for me over the years
10/27/2011 3:30:33 PM • GE Profile 22.2... • Answered on Oct 27, 2011
Not cooling
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
9/27/2011 9:10:21 PM • GE Profile 22.2... • Answered on Sep 27, 2011
I have a freezer on
Hi!
A relay starts the compressor with a higher voltage and then quickly kicks out
It does a lot of clicking (trying to start over and over again)
If thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
I use part no ERP410 POWER START RELAY, CAPACITOR AND OVERLOAD all in one. (110 v)
If you still have trouble Go Here:
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
9/27/2011 8:09:55 PM • GE Profile 22.2... • Answered on Sep 27, 2011
GE model PDCS1NCYARSS Freezee is
NOTE: This
MORE
TIPS AND TRICKS:
Leo Ponder
imufo2
9/19/2011 3:24:21 PM • GE Profile 22.2... • Answered on Sep 19, 2011
FREEZER WORKING FRIDGE NOT COOLING
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
9/19/2011 10:53:43 AM • GE Profile 22.2... • Answered on Sep 19, 2011
My refrigerator is 64 degrees and will not get
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
8/29/2011 12:58:59 PM • GE Profile 22.2... • Answered on Aug 29, 2011
I have a GE Profile
Could be a bad fan motor. A bad defrost part or a bad control board.
Check for ice buildup on the back wall of the freezer. If so you have bad defrost parts or a bad control board.
Enter your model number at www.appliancepartspros.com to find the exploded view to dis-assemble the freezer. You can also order parts from them.
8/20/2011 8:50:03 PM • GE Profile 22.2... • Answered on Aug 20, 2011
Ge profile bottom freezer model
NOTE: This
Also this might be a common Defrost problem, Ice
NOTE: This
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
If you still have trouble GO HERE:
Thanks
for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
MORE TIPS AND TRICKS:
Leo Ponder
imufo2
NOTE: This
For
extra help go here:
Thanks
for using fixya
Leo Ponder
imufo2
8/17/2011 5:24:05 PM • GE Profile 22.2... • Answered on Aug 17, 2011
I am having trouble with
NOTE: This
Then check to see if FREEZER CONTROL is turned warmer which makes REF. colder or vice versa.
Leo Ponder
imufo2
NOTE: This
Leo Ponder
imufo2
8/10/2011 12:20:43 AM • GE Profile 22.2... • Answered on Aug 10, 2011
We have a clicking noise
I recently worked on one. On the back side of the board was a loose solder connection. I soldered it and re-installed the board and it worked. I took some pix and posted em HERE If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
7/28/2011 6:14:50 PM • GE Profile 22.2... • Answered on Jul 28, 2011
Freezer not sufficiently cold.
I would sugest here that the freezer coil has frozen over blocking the air flow to the freezer.
The refrigerator section is still probably ok because the could air will drop down the air duct keeping this section clear.
Try manually defrosting the freezer and see if that makes a difference.
If it does you will need a technician to sort out the automatic defrost cycle for you
4/4/2011 2:18:58 AM • GE Profile 22.2... • Answered on Apr 04, 2011
GE Profile 22.2 Cu. Ft. Bottom-Mount Refrigerator - Stainless-Steel Logo
61 questions posted
Top Refrigerators Experts
vince
Johnny 1000
View Most Popular
GE Refrigerators
  • GE Refrigerators
Most Popular Question
water under vegetable tray believe
  • Refrigerators
