20 Most Recent Bose Around-Ear Headphones - Silver Questions & Answers
3answers
Left chanel on headphones has stopped working
it is a disconnection in the wiring thats the reason behind this problem.
8/22/2010 2:36:59 AM • Bose Around-Ear... • Answered on Aug 22, 2010
Left ear doesnt give out sound
there are two reasons for which your left ear head phone is not working:
1.If the insulation between the wires(copper leads inside the cord) fails....the two leads gets short circuited and it will stop working...OR some times the cord ll be looking good but inside one of the leads got cut then one of the headphones fails...
the solution for the above problem is dont wrap the cord...this ll lead to cut or insulation failure....
2.the speaker in the left head phone got failed...
dont forget to rate me...
good luck...
7/23/2010 8:25:40 PM • Bose Around-Ear... • Answered on Jul 23, 2010
How do i fix the wire, it snapped by the jack?
Here is a link to how to do it:http://www.metacafe.com/watch/1045725/how_to_solder_how_to_repair_headphones/ Please let me know if this helped.
11/29/2009 6:14:58 PM • Bose Around-Ear... • Answered on Nov 29, 2009
2answers
I lost the sound on the right ear of my bose
This may be your headphone jack (what you use to connect it to your ipod or speakers ect.). check the connection there, and if you see the wire became loose near it, that is most likely the problem. You can fix it! With a new headphone jack (available at the Source or Radioshack or other stores like that), and with some manual soldering (it's not too hard, I fixed my myself and I havn't soldered before.) you'll get those headphone to be as good as new. here are the steps to fix this problem.
1. cut your old headphone ******** and strip the wires. you should see two wires; one copper wire and one coloured wire (green or Red) on each cord. there is a total of 4 wires, two per cord.
2. Tin coat the wires. this means to burn the wires a bit (with the soldering iron) and put solder over them. this gets rid of the coating that is on the wires to stop them from shorting out in the cord and helps conductivity when soldering them onto your headphone jack.
3. there should be three holes on your new headphone jack. there should be two prongs left and right of the part you plug into the machine, and there should be one connected to the part that holds the wires once done.
4. connect the coloured wires (red and green) to the left and right prongs of the new jack and secure with solder. These are called the live (or hot) wires because they are the ones that send the signal that makes the sound.
5. connect both of the copper wires to the other hole and secure with solder. these wire are both ground wires, which are very important.
6. by the end, you should have connected four wires. two to the seperate prongs, and two to the third ground hole.
7. test your connection by trying to use your headphones. if it does not work (which may happen, don't get discouraged!) check your soldering. if it is touching any metal it shouldn't be, that means you have created a short circuit. simply burn off the solder (with the soldering iron) and try again.
8. keep trying until you get sound. good luck!
9. Once you get sound, you may want to secure the soldering job. you can either use two part epoxy and put this over your work, or you can tie a knot before you put the cover on you headphone jack. either will work just fine. Also, there sometimes are two metal protrusions that you can bend with plyers to help hold your chord in place.
10. enjoy your fixed, good as new headphones! Enoy hope this helped.
Bee's
10/30/2009 2:02:12 AM • Bose Around-Ear... • Answered on Oct 30, 2009
Fixed broken headphones but sound quality has plummeted
 it sounds as if the wires are wired wrong . yes it is best to solder the wires.all jacks are the same,yours will be stereo i believe. is the braid attached to the earth point, the two other wires attach to the centre of the plug and the other terminal point. these are right and left.
5/24/2009 2:55:09 PM • Bose Around-Ear... • Answered on May 24, 2009
How to find Bose Acoustimass 10 series iv subwoofer circuit diagram
Contact Bose. Good luck with that.
3/24/2024 8:44:03 AM • Bose Audio... • Answered on Mar 24, 2024
Bose 301 Home Theater machine recorded failed 802 - call Bose. What does it mean please?
How do I solve the 801 and 802 errors on a bose 38 ...
JustAnswer https://www.justanswer.com > Electronics Questions Jul 9, 2010 - We have a Bose Lifestyle 38 in stalled with our Home Theater. ... The bose goes out EVERY 24 hours and displays error: call Bose 801 & 802. 1 answer ยท Top answer: Hi and thanks for using JustAnswer!There are a couple possibilities here.Fi ..
3/22/2024 12:28:12 AM • Bose Audio... • Answered on Mar 22, 2024
Pyle P22-03ABTU stereo receiver.
Question edited for clarity. It is a 'Pyle' not a 'Pile'. It is under warranty. Return it, an internal component has failed probably an electrolytic capacitor. One thing you can try is to disconnect it and move it to another room to discount EMF from something. ..
3/19/2024 5:56:26 PM • Bose Audio... • Answered on Mar 19, 2024
Bose Lifestyle Musik Center 614810, das Display flackert beim einschalten, display bleibt dunkel
Question edited to add SPACES. Question edited to English. In a website where everyone speaks English, you appear to writing in German. We are a North American website, we only speak English here. https://translate.google.ca/ Replace the capacitor on the back of the display board. ..
3/12/2024 4:10:47 AM • Bose Audio... • Answered on Mar 12, 2024
How do I replace rear speaker in 2017 Buick La Crosse, premium trim with Bose system
Here are the speakers https://www.gmpartscenter.net/v-2017-buick-lacrosse--essence--3-6l-v6-gas/body--sound-system No one has documented the job. I would get a local stereo / alarm installer to do it as they have the experience and the trim tools. It would be a fast job for them. https://www.google.com/search?q=2017+Buick+La+Crosse%2C+Bose+system+rear+speaker+replacement ..
1/31/2024 5:22:14 AM • Bose Audio... • Answered on Jan 31, 2024
Bose wave radio doesn't turn on with the remote but one time in 20 to30 times pushing the power button.
You can check with new battery in the remote. Next you point a digital camera, a smartphone should do fine, at the infra red transmitter on the front of the remote and then look on the camera screen if you see the ir light flash different pulses for each button. Infra red light can not be seen but a digital camera shows it really well. Confirm this with another remote. Now you know if the remote functions right. Remotes are available on-line or one can use a universal type remote. The IR receiver is often welded onto the circuit board. This means that it is not right behind the front panel window. It can be obstructed, perhaps by dust or displaced. This is generally speaking.
12/2/2023 6:21:42 AM • Bose Audio... • Answered on Dec 02, 2023
Have Bose Wave CD-3000..Used to have old one with bass & treble. This one has built in equalizer, less base!. How can I hook up additional equalizer to boost the base& highs?
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwiDrJriwpSCAxWjhIkEHdvbB40QFnoECBUQAQ&url=https%3A%2F%2Fwww.reddit.com%2Fr%2Faudio%2Fcomments%2Flv3vta%2Fbose_wave_music_system_1_bass_adjustment_help%2F&usg=AOvVaw2QM05DPTaM7aZYtdpULoeF&opi=89978449
10/26/2023 8:11:28 PM • Bose Audio... • Answered on Oct 26, 2023
How can I connect a Bose amp to my 1999 sierra all I want to do I know which wire sends signal to the amp so I can run the speakers from the amp and have better sound
1999 gmc/chevy truck ----------------https://www.modifiedlife.com/1999-chevrolet-silverado-audio-wire-guide/
10/22/2023 8:32:24 PM • Bose Audio... • Answered on Oct 22, 2023
Hi, need to get hold of Bose acoustimass 9 user manual
User Manual Link is given below am_multimedia_guide.pdf (bose.com)
9/14/2023 1:17:57 PM • Bose Audio... • Answered on Sep 14, 2023
Bose Around-Ear Headphones - Silver Logo
Popular Tags
15 questions posted
Top Bose Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Bose Audio Players & Recorders
Most Popular Question
left chanel headphones stopped working
  • Audio Players & Recorders
