20 Most Recent
Belkin Auto FM Transmitter for Most Apple iPod Models - Black Questions & Answers
Will my Belkin ITE Power supply Model No.AC08
Yes as long as the wattage voltage etc... align between the device and the max output of the adapter you should be just fine in this particular case. I have the same adapter and I can not even remember what it initially came with but it has been so handy that I will keep it as long as it lasts. ;)
I have a Belkin iPod
You would have to read the warranty on the product to know for sure if it is in fact, still under warranty. They could possibly tell you that because "you" broke it that it isnt a problem with the device itself. If it came apart that easily i'd call and complain. It may not be working because if the insides fell out some wires may not be attached anymore, or a vital peice of the chip inside of it got damaged somehow so i hope you don't talk to a rude person in tech support for it becuase i think that may be your only option.
Openfit Shokz battery replacement?
Question edited for clarity, typo and CAPS.
Question moved from Cars and Trucks category.
Claim on the warranty irrespective of how long you have had them. They charge $180 but they cost them $20 to buy from China. Package them up and send them tracked and ask them to replace the batteries.
How long is the warranty on AfterShokz?
While we hope you never need it, all new Shokz purchased from authorized retailers come with a two-year warranty that begins on your date of purchase.
Jan 11, 2019
https://www.google.com/search?q=Openfit+Shokz+battery+replacement
My roadking rk4000 wont charge. I turn it off to charge it but there is no indicator light at all, any suggestions?
Are you using the charging cables that came with it? That is a type C. Are you securely attaching the charging cable? A loose connection would keep the battery from charging. If you had a low battery, you would see a red light. That you have no light at all suggests there is no charge left in the battery. I'm not sure the reset will work with no charge which is why you ought to check the cables first.
But turn it off and then hold down the Multifunction button for 10 seconds to reset it. Then turn it back on and see what happens. If you can, test the charging cable on aother device. If you have another type C charging cable, try it, just to eliminate a bad cable. If these suggestions don't work, you may try the manufacturer's customer support.
Can f2100 remote work on my dishtv box?
The F2100 remote is not explicitly listed as compatible with the AerialBox T2100, I recommend using the remote that came with your AerialBox T2100 for optimal functionality. If you have any specific compatibility concerns, I suggest reaching out to Dish TV customer support for further assistance.
