20 Most Recent
Hannspree 28" Widescreen Flat-Panel LCD HD Monitor Questions & Answers
Cannot program comcast remote to work with
try this
press tv button (lights up red)
hold setup button for 10 seconds (tv button blinks twice)
enter code 10030
Press power button on top right. If tv turns off your good
If it doesnt work follow steps above but try these other codes 11348, 11745, 11783
REMOTE CODE and ONLY GET 1 CHANNEL
Hanspree don't really have a manufacturer code for universal remote,
but you can use "1004" or other one of the vizio codes, that works for me.
Burn in mode
unplug and hold the on button for coople of minunute then turn it on
I moved my tv to the bedroom and now I only get
HiThis is very usual if this TV is connected to through RCA(Red,While,Yellow) cables, as most of us make mistakes to have cables into the corresponding jacks. For more help Call Hannspree Support at 888-823-4296(USA).
When I turn on my tv the srceen comes on then
You have to reset everything the cable box,the TV by unplug,replug it an hour later.Let the tv reset itself back to factory setting,and the cable box to upgrade it software.If it work that great, if otherwise you need to change the cable box, I hope this will help to solve the problem....
My TV keeps switching from HDMI 1 to TV by itself
You might want to unplug the HDMI cable at the back of your TV first, then unplug the power cable of your TV for 10 seconds then plug it back in, then plug back your HDMI cable.
I hope this will resolve your issue.
Tv turns on but blank screen?
check the monitor manual setting buttons and check the contrast and brightness level from the fron buttons of the monitor
