20 Most Recent
PNY 1GB microSD Memory Card Questions & Answers
My cell phone won't read my MicroSD 2GB memory chip
first you have to find out where is the problem so do this insert the
micro SD 2GB MEMORY CHIP in a different phone if the chip works then the problem is the phone, some times is possible that
you can buy a defected chip. so hope for the better.
How to reset the password memory card
Transcend??
Mini SD cards, or MicroSD cards, are used in digital cameras and portable media players to house digital media files.
MicroSD cards can house anything from 2GB to 32GB of information.
A write-protection feature gives the owner the ability to lock the MicroSD card to keep their files secure.
If you have a MicroSD card that is write-protected, you can un-write-protect it with a flip of a switch.
Insert your MicroSD card into the adapter that came with it.
Put the data side of the MicroSD card into the data side of the adapter.
Look for the write-protection switch on the left side of the SD adapter.
Flip the switch to the side that reads "Off."
Remove the MicroSD card from the adapter and replace it in the device you were using it with.
or you might
Feel along the lower right and left sides of the Micro SD card to find out if it has a built in write protection switch.
Move the switch over to the "On" position to turn on the write protection feature.
Check the front ports on your computer and see if it already has a built in card reading unit.
Purchase an external card reader that plugs into a USB port if your computer does not already have an internal card reader (see below).
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=card+reader&x=0&y=0
Plug the card reader into any open USB port on the computer.
Power on the computer and let the operating system finish loading.
Insert the card into the Micro SD slot on the card reader.
Wait for a new window to appear that will ask what action you want to take with the Micro SD card.
Click on the link that says "Open a folder to view files."
Right-click on a file if there is just one specific file you want to enable write protection for.
Click on the "Properties" link from the menu that will pop up.
Navigate to the "General" tab.
Click on the box marked as "Read Only" and then close the Properties window.
Close the window and then double-click on the "My Computer" icon on your desktop if you want to enable write protection for every file on the Micro SD card.
Right-click on the name of your Micro SD card in the list of computer drives.
Click on "OK" and then close the window.
Click on "Properties" and then navigate to the "Security" tab.
Scroll down to the heading labeled as "Permissions."
Click on "Deny" under the "Write" section.
or
Slide the switch on the left-hand side of the SD card. If the switch is broken, proceed to Step 2.
Affix a small piece of tape or paper to the top half of the gap where the slider should be.
Do not permanently affix the paper as of yet. 3
Try the card in your computer, using the USB converter stick.
If the items on the SD card are available, copy them to your computer as a precaution.
If that did not solve the problem, proceed to Step 4. 4
Remove the tape or paper and reattach it to the other side of the gap if you mistakenly attached it to the wrong side.
If you are actually trying to unlock a micro or mini SD card, proceed to Step 5. 5
Toggle the switch on the left side of your SD Adapter if you are trying to unlock a micro or mini SD card.
Micro and mini cards do not have switches.
Instead, insert a micro or mini card into an unlocked SD Adapter to work with stored data.
SD Adapters look very much like SD cards and the switch works the same way.
How do I use Transcend microSD, 1GB in an Acer
Turn the computer off.
Insert the card one way, until you feel resistance, and measure how much of the card sticks out.
Then, remove it, turn it over, and insert the card again, and measure again.
Remove the card.
The smaller measurement is the instance where you correctly inserted the card.
Turn the computer on.
Open "My Computer".
Correctly insert the card.
The "My Computer" window will update, in less than 30 seconds, to reflect that the card has been detected, and Windows has been configured to access the card.
Double-click the changed icon, to "open" the files/folders that exist on the card's memory.
My computer is not recognizing
In this instance, you might want to consider either borrowing, or, purchasing and card sd reader. Some computers just don't read these cards from their built-in slots, so, using an sd card reader often fixes the problem.
Hope this helps. :)
I cant open my
- Go to registry, follow the path
- HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevice Policies
- There you will find a key "WriteProtect", check the value.
- If value is '0' then OK, if '1' then make it '0'
- To change the value, double click at the key "WriteProtect", one manu will pop up. change the value.
Dont know how to get pics on to card
in the phone settings it will have an option to save to phone or save to memory card etc, nothing will pop up in the phone, its just extra storage, try bluetoothing from your pc to phone to see where the pic arrives, will prob be on the card, but maybe its set to store on phone instead.
Load music to my Micro SD
Thats not a copysight isssue i think you have a virus problem ot tey changing the usb port because speed of data transfer may also be the problem
Curropted memory card
You musr buy a new one but if you have some important data you can recover using recovery software
I cannot delete pic from mini sd card. Computer no longer does it
Check to see if the write protect switch is in the locked position. This is a way to protect info on the card. There is a very small switch on the side of your memory card. Place the switch in the opposite direction and see if this works. If not post if the memory card is seen by your device or is it like it is not there at all.
Music
use ur cellphone data connection wire to plug to the computer with the card inserted in ur cell phone...or use a card reader seperately for raeding ut memeory card load it with songs then insert to ur cell phone..
Pny bravo laptop memory installation problem
You need to go to your manual and check if this new RAM is on the qualified venders list. Many motherbaords have problems with RAM and are picky about which you put in it even being the same speed and specs. If you dont have the manual , go to thier website, there is a list threr related to your laptop. also make sure the RAM is seated properly in the slot, that also cn cause an err
