20 Most Recent
JVC LT-46AM73 46 in. LCD HDTV Questions & Answers
46" JVC model 46AM73 light will change from green to red and red to green each time you push the power bottom but no picture or sound. All the condensors look to be good.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
I HAVE A JVC 46" LT-46AM73 HD LCD TV. WHEN I PLUG A FIRESTICK OR XBOX ONE IN ANY OF THE HDMI PORTS THE SCREEN GETS BLUE DOTS AND THEN THE SCREEN FLASHES TO WHITE SNOW, THEN BLACK, THEN BACK RAPIDLY.
Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Red light comes on but there is no picture
Could be a number of things. Sometimes those tiny pressure pads under the buttons tend to stick... l.e.d comes on but TV does not. Danger is popping the buttons out to fix it, you may not be able to get it back in.. but that's the good news.
Was there any electrical damages, such as lightning or faulty wiring? Did you smell anything burning, like hot plastic? Does it make a high pitched but barely audible whine when you turn it on? And does it work on any input at all, either VGA/Svideo or the Component/HDMI ports?
Loss of power it wont turn on
Sounds like a component failure in the circuit.possibly been power surged if you did not have it plugged through a good surge protector.
I have a JVC lt-46am73 tv. Yesterday the power
Hi Ron. Sorry that you are having problems... I know how frustrating it can be. The problem is most likely your Power Supply Board. The capacitors used on the Boards for most sets made in the last 10yrs use an extremely cheap and unreliable capacitor. If you can take the back off of your set, take a look at the board where your Power Supply Plug goes in. On that board, take a look at the capacitors. If you need to - you can Google, "pictures of bad capacitors" and you'll see exactly what a blown capacitor looks like. If the tops are not completely flat across, there is any "doming" to the tops, the scored "+" on top of the capacitor has any spacing, cracking, and/or shows where any liquid has escaped... you have a bad capacitor. You can replace these capacitors and/or pay someone to do it for you, but I always advise to just power a new Power Supply Board. They are very easy to install. You can typically pick one up for a couple hundred $$ and save your TV from a junked fate. Hope this helps and good luck.
Tv won't turn on
This is a frustrating problem, but more details are required to solve it. Have you found the power switch on the TV? Are the batteries installed properly (facing the right way) in the remote? Is the TV connected to a working power circuit? If power is getting to the TV and the power switch doesn't work, I'd return the TV.
JVC 43" (109cm) HD Ready Plasma TV PD43N30A. Chunghop universal remote codes for JVC pd43n30a
Question edited for a lot more clarity, plus
Chunghop not chungCHOP :>D
JVC: 089, 161, 909
CHUNGHOP Universal Remote Control Codes
codesforuniversalremotes.com
https://codesforuniversalremotes.com > chunghop-univer...
Jul 25, 2019 -
CHUNGHOP Universal Remote Control Codes ; Aiwa: 009, 057, 058 ; Samsung: 618, 619, 620, 621 ; Philips: 013, 023, 024 ; Hisense: 676, 677, 707, 898
