20 Most Recent Maytag EPICz 3.7 Cu. Ft. Questions & Answers
0answers
3answers
What does the error code Sd mean on my Maytag Epic
Hi
Thanks for using FixYa. Error 5d/Sd means too much detergent was used. Try the following procedure---
- Run the unit through a RINSE/SPIN cycle.
- Run a NORMAL cycle without adding any detergent.
This should clear the unit of the excess detergent. If still the problem persists, then please check the following things--
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump, pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic Test or any cycle.
Please accept the solution if the issue is resolved post a comment for further assistance.
Thanks
Rylee
8/29/2016 9:56:01 PM • Maytag EPICz 3.7... • Answered on Aug 29, 2016
0answers
Water colects in the soap dispencer and is there after wash is complete
replace the dispenser
1/28/2014 4:11:17 AM • Maytag EPICz 3.7... • Answered on Jan 28, 2014
My Maytag Epic Z front load washer stops working
Hello, welcome to FixYa.
Based on your information posted I understand you have the Maytag Epic washer, correct ? The F21 error on these built by Whirlpool means an excessive drain time or excessive suds was detected as you may or may not already know.
If you follow the link to my solution to this error designed specifically for "do-it-yourselfers" you should be fixed up in no time. (It's much quicker for me than pasting or retyping the complete solution several hundred times, that's how common this is).
This will also instruct how to unlock the unit...though once the water is gone it likely will unlock without issue, if it is at all an issue. Many times it is, but it's just a by-product of not draining correctly.
http://www.fixya.com/support/r9090359-whirlpool_frontload_f2_f21_sd_suds
Thank you for choosing FixYa. Please take a moment to rate the info provided here and a testimony on your experience here at FixYa today is appreciated.
Let me know if anything isn't clear or you need further assistance, Good luck.
Regards,
Macmarkus :)
9/26/2011 1:43:30 AM • Maytag EPICz 3.7... • Answered on Sep 26, 2011
Machine stopped mid cycle, won't spin or did
next time send the model number,open the door,look around the opening where you put the clothes in and you'll see a tag with the model and serial numbers,it has to drain first before it will spin,check the pump,get a shop vac and vac out all the water,remove the bottom panel and look at the pump,if the middle of the pump can be removed turn it counter clockwise slowly until the water starts to leak out and vac it up until all the water is out,then remove the middle part of the pump and clean it out,if the middle doesn't come out remove the hoses and check the pump to see if anything is in it and check the hoses,after you remove any debries you find fill it with some water and put it into a drain to see if the water drains,if it doesn't you can check the pump again to make sure you cleaned everything out,stick your finger in and fell around the impellar to make sure it's clear,if it's clear replace the pump.usually an error code will come up but if it fills and agitiates but won't drain i would start at the pump.hope this helps.
8/15/2011 10:21:00 PM • Maytag EPICz 3.7... • Answered on Aug 15, 2011
2answers
My maytag washer when it starts to fill it stops
  • The F11 code means there is an electrical with the Maytag Epic washer. This could involve wiring, fuses or a number of other issues.
Prevention/Solution
  • Press the "Pause" button twice to stop the current cycle. Press the "Drain" button to remove any excess water. Try to run the washer again. If the F11 code repeats, shut the washer off and contact a service agent.
Types
  • The F11 code could appear as other F codes. F01, F03, F04 and F05 all indicate electrical issues with the washer.
Considerations
  • The problem may be with the outlet your washer uses. Stop the washer, remove the plug and try it in another outlet to see if the F11 error code goes away.
Misconceptions
  • The FH error code may be mistaken for the F11 code. The FH code signals a water supply issue and has nothing to do with electrical problems. Check the LCD screen to ensure you read the proper code.
7/28/2011 9:25:59 PM • Maytag EPICz 3.7... • Answered on Jul 28, 2011
Why would my Maytag Neptune front load washer stop draining water
Troubleshooting chart-
https://machinecompanion.com/maytag-neptune-washer-not-draining/
4/4/2024 4:19:35 AM • Maytag Washing... • Answered on Apr 04, 2024
Need to ID Maytag dryer with no label?
The label should be at the back where the power goes in. The label is supposed to be not able to be removed (strong adhesive or metal and riveted. There may also be a service manual and wiring diagram in the top console. Pictures and mentions here, but no model details. You could also try emailing Maytag. https://www.google.com/search?q=maytag+ensignia+heavy+duty+super+size+capacity+quiet+series+200+10+cycles You can upload pictures, but we know what the machine is because of your excellent description. After more searching it may be MDE4806AYW although it says 12 cycles? https://www.google.com/search?q=maytag+%22ensignia%22+heavy+duty+super+size+capacity+quiet+series+200+10+cycles+manual ..
3/28/2024 12:22:21 AM • Maytag Washing... • Answered on Mar 28, 2024
Fix for error code E02F06 on Maytag mhw7000xw front load washer
I found this reference on the web ... from a repair technician on a Maytag Maxima>>> So I'm really sorry to bring you this bad news, but let me explain your error codes. F06 E02 is a communication error between your MCU (motor control unit) and your CCU (central control unit). You'll want to remove the top panel, the control panel, and then the front panel of the washer and make sure the wire connections to the motor control unit below the tub are all secure. If everything checks good, you'd need to have the MCU replaced. From a different reference on a similar Maytag MHW6000XW2 ... also indicating communication issue capture-o5w4phgx25od3lsv3yfk4e0a-4-0.png Usually ... hidden somewhere on the inside of the washer you will find the service technician paperwork which has all sorts of additional detail. Helpful? Good luck on your troubleshooting!
3/27/2024 11:50:27 PM • Maytag Washing... • Answered on Mar 27, 2024
37 questions posted
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Washing Machines
Most Popular Question
maytag epic z front load washer stops
  • Washing Machines
