20 Most Recent
Nokia E90 Cell Phone (Unlocked) - Black Questions & Answers
Inner display backlight works, but it doesnt display anything, could this be the cable sockets problem? Thank you for help.
If you look very closely (check in different lighting conditions), do you see anything on the outer screen at all? You probably won't be able to fix this yourself, but you might be able to determine if something is loose. Press a button on the phone, which would normally make the outer screen light up. Hold the phone firmly in one hand and smack it into your other, outstretched hand at different angles (i.e. smack the right side, left side, top, etc. several times). If the screen comes back on even for a moment, then something is just loose, and the repair shouldn't be costly. If you can see a faint image on the screen in some lighting condition, but smacking the phone doesn't help, then the problem is the backlight and you will probably need a new screen. If you can't see anything on the screen at all, and smacking doesn't help, then the problem is unknown
go to nokia care
Network Restricted E90
To unlock nokia mobile,youn have to show your IMEI number and service operator,You will get your IMEI number back side of mobile,just remove the battery.
My e90 on whatsupp not wark
Please check your internet connection Khan. I am sure you are either not on wifi or not on 3g due to which your watsapp is not working.
Lock code
Try Hard Format. First Switch Off Mobile Then Press *+call button+3+Powr Button. You Phone will be in Factory Mode.
I forgot my lock code
try doing this im sure this one will resolve your issue
hold button CALL + 3 + * + ONE TOGETHER WAIT MOMENT
AND YOUR PHONE DELETED SECURITY LOCK
