20 Most Recent Verizon Communications Samsung Juke Cell Phone - Red Questions & Answers
necesito saver como bajar las fotos o imagenes de micelular 470 samsung juke a mi pc .tienen algun controlador o respuesta favor mademela.
Verizon... | Answered on Jun 20, 2019
Does the Verizon logo flash when you plug it in? I had this same problem. Take the battery off. Plug the phone in. Observe the flashing logo. Put the battery back in. Observe "Charging..." screen. Power on. Unplug. Good to go.
Verizon... | Answered on Feb 17, 2019
no you cannot the samsung juke has two memory units one 2 gig mp3 player memory and a 1 gig (i think) for ringtones and sounds and contacts and stuff like that. you cannot put a mmory card into the samsung juke
Verizon... | Answered on Dec 03, 2018
If you had your SD card set to store the pictures, then you can remove it from the phone and use a card reader to transfer your pictures. Walmart sells a Vivitar card reader that will take the SD card without the need for an adapter.
Verizon... | Answered on Jul 28, 2017
First call your provider to shut it off if you lost it outside your home. If you think it is in the home...call it. It probably has a GPS chip in it..have your provider locate it that way.
Verizon... | Answered on Sep 09, 2016
This means that you need to replace the battery.
Verizon... | Answered on Dec 11, 2014
Power the phone off remove the battery for a minute and power back on
if it continues it is likely a button failure make sure it dosent seem stuck
seek the closest repair store
http://www.verizonwireless.com/b2c/storelocator/index.jsp
Verizon... | Answered on Nov 07, 2013
press Camera button + volume down + power button ( together )
if the mobile turn on and show ( download or any word .. so you can fix it by changing the software )
Verizon... | Answered on Jul 26, 2013
Go to number 9 that will be settings and tools Then go to number 8 which Is phone settings Go to number 4 wich is language Im vaniah 9 years old hope it helped you
Verizon... | Answered on Jun 13, 2013
Either the charger is not working or you got a bad plug inside the phone I would take this to a verizon dealer and have them try some things with it. If this phone has a contract to it I know verizon would repair or replace this phone.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Verizon... | Answered on Dec 18, 2012
i dont know
Verizon... | Answered on May 07, 2012
you can get the master reset code from service provider and Unlock it....
Verizon... | Answered on Aug 10, 2011
You get this when you completely reset the phone. Please contact Verizon and after they activate/program the phone, this message will be gone.
Verizon... | Answered on Jul 23, 2011
Samsung does not offer a Data Kit software package, for the purpose of transferring data between the handset and a personal computer or for using a Verizon Handset handset as a modem for a personal computer. However, depending on the model, there may be a media card slot located on the side of handset or in the battery compartment that allows information to be transferred to a personal computer with the use of a media card reader. For information on selecting the correct media card reader, please visit the Samsung Accessory website or check with a local computer store to purchase a media card reader compatible with both your computer and the media card type.You can download Samsung juke SCH-U470 drivers from samsung official site. Download Device(Install),USB Driver (ver.4.23 v3.4) compatible with Windows 98/XP/VISTA from visit this link http://forums.techarena.in/portable-devices/1233247.htm thanks
Verizon... | Answered on Jun 29, 2011
Hi tommyboy_69,
I am afraid there are no replacement for your device.
i hope this helps.
Verizon... | Answered on May 17, 2011
At first set up your phone with charger and start power supply. Then press the on button and main button at the same time. try it for some times and your phone will turned on again. But check your battery first. Is is dead or not?
thanks
Arnob
Verizon... | Answered on Apr 06, 2011
Verizon Communications Samsung Juke Cell Phone - Red Logo
Popular Tags
64 questions posted
Top Verizon Communications Cell Phones Experts
RONALD CARTER JR
Ekse
Marvin
Marvin
Are you a Verizon Communications Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
  • Verizon Communications Cell Phones
Most Popular Question
samsung verizon phone got
  • Cell Phones
