20 Most Recent
Energizer Duo Battery Charger for AA and AAA NiMH Rechargeable Batteries Questions & Answers
Hi There,I have a Topcon RL-H3C Laser and its not turning on.
There could be a few reasons why your Topcon RL-H3C laser is not turning on. Here are some things to check:
Make sure the batteries are inserted correctly, with the positive and negative ends in the right positions.
Check that the battery contacts are clean and free from any corrosion or dirt.
Try cleaning the power switch and any other switches or buttons with a soft, dry cloth to remove any dirt or debris that may be preventing them from working properly.
If none of the above steps work, it's possible that there may be a problem with the internal circuitry of the laser. In this case, it's best to take it to a qualified technician for repair.
Also, if the laser has been stored for a long time, it's possible that the batteries may have leaked and damaged the contacts or other components. In this case, it may be necessary to replace the affected parts.
2/25/2023 8:42:28 AM •
Energizer...
Answered
on Feb 25, 2023
Can I use an Energizer Ultimate Lithium 9V battery in a Fire Sentry Model 0914?
One possible problem with using a battery that lasts a long time is maintenance.
When a battery needs changing annually or even twice annually, the smoke alarm is opened and somebody gets to look inside and that not only reveals whether there is an excess of dust and spider webs inside or blocking the grille, it also serves as a reminder to test the alarm periodically.
A web across the grille can stop the alarm working and when a battery lasts for five years plus, the habit of testing the alarm weekly or even monthly can soon be lost.
10/14/2018 8:11:57 PM •
Energizer...
Answered
on Oct 14, 2018
How do you use the energizer shutter remote
plug lead in remote, and other end in camera, put camera on tripod and turn on camera point at subject, and press button on remote to take picture, picture will be better because there is no shake. if you want to youse timer then read instructions. to much to explain, if you haven't got the instructions then download them of internet. hope this helps.
10/3/2014 5:21:15 PM •
Energizer...
Answered
on Oct 03, 2014
My open view is not showing any pictures but showing information about programs playing what might be the problem
Some steps you can try:
Check Picture Location:
Ensure that the pictures you want to view are in the same folder location. Sometimes, if the images are scattered across different folders, they may not appear correctly in the photo viewer.
Repair or Reset the Photo App (for Windows 11):
Go to Settings > Apps > Photo.
Click on Advanced options.
Choose either Repair or Reset to address any potential issues with the Photo app.
Enable Thumbnail Previews (for Windows 10):
Open File Explorer Options:
Type "file explorer options" in the Windows search bar and select the first result.
Switch to the View tab.
Ensure that the option "Always show icons, never thumbnails" is unchecked.
Click Apply and then OK to save the changes.
That is about all I can offer. If you repost, include brand and model.
4/19/2024 8:18:20 PM •
Cameras
Answered
on Apr 19, 2024
