20 Most Recent GE Profile 25.1 Cu. Ft. Side-by-Side Refrigerator with Bottom-Mount Freezer - Stainless-Steel Questions & Answers
Water Dispenser Making Noise
Usually this means you forgot to turn the water on, once water is in the valve it should quiet down
1/1/2018 12:06:51 PM • GE Profile 25.1... • Answered on Jan 01, 2018
2answers
GE Profile PFSS6PKWASS ice maker quit, water and
Try defrosting it completely then re start it again. Shut off the water suplly. Maybe the service guy forgot to turn the water supply off.
10/6/2011 5:03:38 PM • GE Profile 25.1... • Answered on Oct 06, 2011
The ice maker leaks in
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
9/24/2011 9:48:36 PM • GE Profile 25.1... • Answered on Sep 24, 2011
I have a GE Profile French door Fridge that's
is compressor running?
9/23/2011 4:37:26 AM • GE Profile 25.1... • Answered on Sep 23, 2011
On my profile french door
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
If you need more help go here:
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
9/16/2011 5:10:14 AM • GE Profile 25.1... • Answered on Sep 16, 2011
I HAVE A GE PROFILE/FREEZER
NOTE: This
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
If you still have trouble GO HERE:
I'm
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
8/15/2011 3:47:58 PM • GE Profile 25.1... • Answered on Aug 15, 2011
WHY IS THE WATER SO
filter could be the problem ...good that you are trying it first.... if it does not help it is possible the water valve is not opening all the way as it is a solenoid and can get stuck partially one way or the other....good luck to you
1/12/2011 3:32:20 AM • GE Profile 25.1... • Answered on Jan 12, 2011
Whole refrig stopped working. I
Seems your freezer is short circuited. Common problem is on Compressor. Just the compressor first for shorted. Use OHM meter to make measurement. You can use this instrument to check other parts of freezer. Note : disconnect the power before take measurement.
Regards
12/17/2010 2:06:35 PM • GE Profile 25.1... • Answered on Dec 17, 2010
How do I change the water filter on my GE Profile
The filter on the one I know (see below) has the water filter in the upper right of corner of the refrigerator. In my experience, you should move all food from that side of the top shelf of the refrigerator and put a shallow pan underneath. Some water will spill.
First get the cover out of the way by pressing in on the tab on the front and tilting the cover down. Remove the old cartridge by rotating it counter-clockwise. The front end of the cartridge is shaped to make a handle. Use care in case any air bubbles have built up behind the cartridge; they could force the cartridge out suddenly. Remove the foil from the end of the new cartridge. Line up the arrow on the cartridge and the arrow on the cartridge holder and then rotate the cartridge clockwise until it stops. You will feel a "click" as it locks into place when properly installed. The grip on the front should be positioned vertically. If the cartridge is overtightened, it will leak. Close the cover and the refrigerator doors. Run the water dispenser for 3 minutes (1 1/2 gallons of water) and discard the water. This will clear the line and prevent future sputtering. It will probably sputter while you do the inital clearing.
Reset the water filter replacement light by pressing and holding the Reset Water Filter pad for 3+ seconds.
The manual for most GE refrigerators are available online from the geappliances.com site. A very similar unit has the manual here: http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SpecPage&Sku=PFSS5NJWSS .
I hope this helps.
12/16/2010 12:52:13 AM • GE Profile 25.1... • Answered on Dec 16, 2010
Ge profile fridge side by
Good day,
Assuming the temperature in the freezer is normal. 10 degrees or less. then it should be one of the 3 items here.
1. Partially plugged filter.
2. Water valve in the back bottom of the machine failing to open properly.
3. Partially blocked supply line from the house or it's connection fittings which ar more common than the line itself.
As well, if the water fill valve has a small leak on the off cycle, the fill tube running from the outside back of the machine that supplies water to the ice maker cavity may have ice starting to cause a blockage.
11/6/2010 5:14:49 PM • GE Profile 25.1... • Answered on Nov 06, 2010
PFSF5NJWABB - Not cooling or
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
8/28/2010 12:12:35 AM • GE Profile 25.1... • Answered on Aug 28, 2010
Which way is the switch on for th eice maker
circle is on
6/1/2010 2:48:16 PM • GE Profile 25.1... • Answered on Jun 01, 2010
2answers
GE Profile french door refrig not cooling but freezer is cold
your damper vent door is not opening to let the freezers cold air in to the refrigerator compartment,its located between the refrige and freezer,also make sure the evaporator fans are running to move the cold air
5/16/2010 12:02:53 PM • GE Profile 25.1... • Answered on May 16, 2010
Water dispenser apparently broken
Yes. Order a new one first. Take pix as you remove the old one and label each screw in case they vary in length. Joe
4/24/2010 12:53:46 AM • GE Profile 25.1... • Answered on Apr 24, 2010
GE Energy Star French Door Bottom Freezer handle popped off
You cant find a hole to insert screw from outside. It is true, and you can't fix it yourself to what it looked like earlier. The company first screws in through the handle and then covers the hole made by it with the material of the handle. If you have to fix it yourself, you can only pierce those screws through the handle leaving the mark behind. If you don't want that, contact your company or dealer.
4/22/2010 9:22:00 AM • GE Profile 25.1... • Answered on Apr 22, 2010
GE Profile 25.1 Cu. Ft. Side-by-Side Refrigerator with Bottom-Mount Freezer - Stainless-Steel Logo
36 questions posted
Top Refrigerators Experts
vince
Johnny 1000
View Most Popular
GE Refrigerators
  • GE Refrigerators
Most Popular Question
whole refrig stopped working
  • Refrigerators
