20 Most Recent Maytag Bravos 7.0 Cu. Ft. SuperSize Capacity Plus Gas Dryer Questions & Answers
Just had the sensor replaced on my maytag bravos
Possibly a bad circuit board for the digital read out, when you start cycle the connections on the board are room temp. after progressing thru cycle for a period of time the connections warm up and cause circuit failure for the lighted read out. However all the other functions of operation are not affected. A quick look at the board itself would most likely indicate a problem by charred or discolored solder connections.
11/20/2017 1:42:30 AM • Maytag Bravos... • Answered on Nov 20, 2017
Washing machine out of balance
Unbalanced load. I read somewhere the cure from the manufacturers is to remove the counterweight at the base of the machine and add springs to stabilize lateral movement. You could see the actual service matters bulletin if you paid the $500 subscription fee. LOLService manual anyone?Bravos/Cabrio washer breakdown If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
7/23/2012 3:18:49 PM • Maytag Bravos... • Answered on Jul 23, 2012
What would make my dryer not heat up
could be a limit switch or the dryer element is bad.
7/7/2012 8:56:23 PM • Maytag Bravos... • Answered on Jul 07, 2012
Dryer dosen't blow air
replace the blower belt and it will blow air from the dryer
4/20/2012 7:22:46 PM • Maytag Bravos... • Answered on Apr 20, 2012
I have a Bravo gas
remove the back,, the fan is located on the rear of the motor shaft and has reverse threads, either it is a slip on one with a clamp that has come off, or its running and you just can't tell, either way you may want to check it,, as always ,, be very careful as you do this,, don't touch anything that is connected to electrical
6/10/2011 1:52:41 AM • Maytag Bravos... • Answered on Jun 10, 2011
Dryer will not restart after
It is your motor getting hot. Try running a empty load first, then do a load. That will telling your motor is getting hot.
4/30/2011 6:09:53 PM • Maytag Bravos... • Answered on Apr 30, 2011
Have a day old Bravos
Hi you can call maytag and they will send someone out to look at it free of charge, it probably either needs leveled or they didnt remove shipping bolts. Usually brand new washer wont be broke 9 times out 10.
Sean
3/26/2011 9:49:46 PM • Maytag Bravos... • Answered on Mar 26, 2011
POWER COMES ON WHEN YOU
Unplug the machine for about 5 minutes then plug back in to reset control. If still no display, replace control.
Kelly
3/24/2011 9:51:25 PM • Maytag Bravos... • Answered on Mar 24, 2011
2answers
We just installed a new Maytag Bravos dryer and
did you call the factory,if it's under a year it should still be under warranty,you shouldn't have to pay a thing,i would have a problem with that too.
10/30/2010 2:43:55 PM • Maytag Bravos... • Answered on Oct 30, 2010
I have a brand new Maytag Brovos dryer that is
i would say there is a restriction in the vent tube, disconnect and let it run and see if it works better.
10/17/2010 2:13:56 AM • Maytag Bravos... • Answered on Oct 17, 2010
Gas bravo serie 3000 dryer turns on electronically
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
9/21/2010 1:40:57 AM • Maytag Bravos... • Answered on Sep 21, 2010
I have a Maytag Bravos
What is the model number of the actual unit, It may be the door seal or boot causing the problem,
9/15/2010 6:20:17 AM • Maytag Bravos... • Answered on Sep 15, 2010
Maytag Bravos Dryer (1 mo. old) timer does not change from start
Maytag Bravos 400 Series Dryer purchased August 2009 - November 2009 required repair as I also experience the timer readjusting itself to excessive extended drying time when clothing was bone dry and hot. Sometimes extended to 1 hour 40 minutes! Serviceman stated problem was the Sensors in the dryer. Part number 8577274 Thermister and "Old Ohmed out open" whatever that means as listed on my repair ticket. Have not had that particular problem since. Make sure your dryer vents from dryer to outside are clean and clear of lint. Will help immensely. I have many other issues with this dryer it has been down FOUR times in 9 months. Fighting with Maytag to replace this lemon!
5/28/2010 6:55:53 PM • Maytag Bravos... • Answered on May 28, 2010
Drum is not turning
If the machine turn on and appears to heat properly, It usually happen when the belt breaks or gets out of the pulley. A more serious issue may be the motor broken.
12/24/2009 7:35:10 PM • Maytag Bravos... • Answered on Dec 24, 2009
Maytag Bravos 7.0 Cu. Ft. SuperSize Capacity Plus Gas Dryer Logo
38 questions posted
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
View Most Popular
Maytag Dryers
  • Maytag Dryers
Most Popular Question
brand new maytag brovos dryer
  • Dryers
