20 Most Recent XFX NVIDIA GeForce 8600 Graphics Card Questions & Answers
remove all video drivers and restart the laptop .try work with generic driver, and check the laptop. after that go to nvidea web site and download the driver and install
XFX NVIDIA... | Answered on Jun 05, 2017
Uninstall the driver and the card utilities before turning off. Turn off then remove the card you want out. The remaining card must be placed on the priority card socket, meaning the first card socket for video. Then boot up and reinstall the drivers and utilities.
XFX NVIDIA... | Answered on Mar 13, 2014
replace the fan with one from the other card. i would also advise repaste the gpu with antec 7 diamond paste. be sure to remove all dust. youtube have videos on this matter that will show you step by step. i hope this helps you out
XFX NVIDIA... | Answered on Mar 12, 2014
Can you be more specific, what is your problem?
XFX NVIDIA... | Answered on Oct 22, 2013
Dear Sir,
I need Windows 2003 server X32 Driver for GF 8600GT 540M 512MB DDR2 TV DVI PCI-card
ALL THAT STANDS IN THE MANUAL.
XFX NVIDIA... | Answered on Sep 10, 2013
windows 7 64bit in not instal drivers
XFX NVIDIA... | Answered on Aug 09, 2012
type nvidia drivers in google search
then click on the first link
http://www.nvidia.com/Download/index.aspx?lang=en-us
fill in the correct info of u r graphics card ....
XFX NVIDIA... | Answered on Jul 13, 2011
The model number would be helpful in determining exactly which card you have but, s-video should certainly work and they also make an adaptor that converts s-video to component video if that's something that you want. You will have to, if you haven't already, get into "control panel" and then get into "personalization". There you should see your two monitors. Here you can adjust your resoulution. You will also have to check in "device manager", click on the box(on right) next to "monitors", it should show your 2 monitors. Right click on each, one at a time, and in the dropdownlist you should see "disable" if you see "enable" click on that and exit. If you see any warnings, !, ?, or a yellow triangle, click on thta and follow proceedure. You may also want to click on the box next to "display adaptors" and check for warnings, right click on and make sure it' also says "disable" in list with both monitors connected.
XFX NVIDIA... | Answered on Jun 10, 2011
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM is securely seated
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
XFX NVIDIA... | Answered on Apr 22, 2011
I would suggest you lower your resolution settings from your video card to your monitor. Possibly they are to high for your monitor to handle. Go into control panel to change your settings at a lower rate and see if it runs any better.
I hope this helps you out if so please leave me some feed back.
XFX NVIDIA... | Answered on Apr 03, 2011
XFX NVIDIA GeForce 8600 Graphics Card Logo
129 questions posted
Top XFX Computers & Internet Experts
Ekse
Thomas F. Schneider
1400Slugg
Are you a XFX Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • XFX Computers & Internet
Most Popular Question
all in
  • Computers & Internet
