Call for warranty service it is in the owners manual I had a customer 2 weeks ago plugged in a 120VAC oven into a 120VAC outlet that was wired for 208/240VAC doubt if thats your problem but call for service
May I get the make and model # to help you more. On some ovens if you hold the clock button for secondes it should turn off. I need the make and model # to be-sure.
Hello there: normally when the dreaded f3 code appears it is refvering to the temperature sensor for the oven temp that has shorted out or is going out and needs to be replaced Here is a replacement one for this oven and apart number
Item
# 1364Price $35.70In
Stock? YesOven
sensor kit, 6 inches long. Includes two harness adapters for a variety
of applications and installation instructions.Qty Order now and this item will
ship today.Or
it'sFREE!(Click
to enlarge) Grid is 1 inch squareItem
# 1365Price $32.50In
Stock? Yes
Hi, I would want you to look for the below mentioned things, in order to resolve your issue.
check for a blown fuse or tripped circuit breaker
Also in addition to that please check for the main wiring connection from the house, as whenever the range/oven gets burned it breaks the connection. Then you may have to replace the power cord to the range/oven, and the terminal block that the wire is attached to.
There may be a broken or burned wire at the back of the range/oven. If you repair any of the wires, use only proper appliance-grade wire and wire connectors.
Please let me know if the provided information has been helpful. Please rate me if the information provided was able to help you.
It should run with you setting anything but clean. You can obtain a copy of the owners manual from the maytag site or by googling your maytag appliance model number.
Open the door and look inside near the base of the door. It will say the voltage. Ours is 110. You can go to the maytag website to get an owners manual and installation manual for free.
Remove the flame spreader panel to access the ignitor.
Place a clamp on amp meter on the ignitor wire and turn the oven on.
If you read less than 2.9 amps, replace the ignitor.
If you read 2.9 to 3.2 amps replace the gas safety valve.
f your 2008 Maytag double oven's lower door is locked, here are some steps you can try to unlock it:
Press Cancel/Off Key: Start by pressing the Cancel/Off key. Wait for 20-30 seconds, then try to open the door. Sometimes this simple latch reset can do the trick.
Power Cycle: Turn off the power at the circuit breaker or fuse box for one minute. After that, turn the power back on. Allow the oven to cool for approximately 30-90 minutes, and then move the latch arm to the left to unlock the door.
Self-Clean Cycle Interruption: If the door locked during a self-clean cycle, select the "Self Clean" option, and then choose "Cancel". Wait a couple of minutes, and then try to start the cycle again. If the self-clean cycle was started by mistake, press the Cancel/Off key. The oven will need to cool to around 200°F (95°C) before the door can open.
Remember to ensure that the oven is cool and the power is turned off before attempting any of these steps. Hopefully, one of these methods will help you unlock the oven door! Your manual might prove helpful. Oven is Locked - What to Do - Product Help ' Maytag
There are two types and they both work to a theme. Modern Oven hinges are inset into the door itself, so you just split the door apart, take the old ones out and the new ones in. The other type have the hinges inside the oven itself between the outside of the oven cavity and the outer panel. With those you pull out or remove the wall oven and look at the back and underneath for the screws. Remove the side panels, remove and replace the hinges.
Door Mounted Hinge
Side Mounted hinge
