20 Most Recent
Kaz Sesame Street Elmo & Friends Humidifier - Blue Questions & Answers
My humidifier isnt working properly, it is not using any water
Make sure you soak the wic with COLD water and don't ring it out. Make sure when your putting the tank back in that you don't spill any water into the fan vent. If you get even a splash into the vent, it makes that awful loud motor noise. If this happens just let it dry out on it's own(over night). Also try cleaning the wic tray. It tends to get slimmy from the water sitting in it. If you ever see that your tank is empty, wet your wic when you refill it. Make sure you rinse and wet the wic EVERYTIME you refill the tank. The wic dries out fast and can start smelling pretty bad if you don't rine it regularly.
How do I clean this
The outside you can clean with warm soapy water. The inside can be flushed with a 50/50 solution of White Vinegar and Bottled Distilled Water. Fill the tank and run the unit until the tank is almost empty. Pour out the remaining solution and fill the tank with more of the Bottled Distilled Water. Operate the unit for 30 minutes and the previous solution should have been flushed out by then. I would recommend using Bottled Distilled Water all the time rather than tap water. As tap water has a lot of minerals in it that can cause calcium scale and clog the unit.
Hope this helped you.
I need a kaz steam
How many watts does
Kaz Steam Vaporizer Safeguard Model 76 use???? I think it's using a lot of electricity. Anyone with clarity please?
