20 Most Recent
Xerox DocuMate 510 Document Scanner Questions & Answers
Xerox documate 510 locking up on windows 7
Hello.I am a Support Engineer with Xerox Scanners. It sounds like others have given you great advice to address paper jams or locking up that you may be experiencing. If the "locking up" that you are experiencing is coming from the software, I would recommend updating to the latest available driver. I have written an
article on the process that may be of use to you.If you continue to experience trouble, please feel free to contact us by calling 800-648-0410.Regards,Xerox Scanners Support
Assembly instructions needed
1 Open the printer cover and prop it up with the support brace located on the right-hand side of the cover. It's similar to the way a car hood is propped open.
Step 2 Remove the black FINE ink cartridge from its container and locate the protective tape. Gently remove the protective tape used to cover the print head nozzles and electrical contacts.
Step 3 Insert the black FINE ink cartridge into the printer slot labeled "B." It will rest on a slight angle. Push the cartridge up and back until it clicks into place.
Step 4 Repeat the process for the color FINE ink cartridge, placing it in the slot labeled "C."
Step 5 Raise the printer cover slightly to loosen the support brace. Fold the brace inward and replace the cover to its closed position.
Step 6 A green LED light will flash on top of the printer. In about a minute, the LED stops flashing and displays "1." Once the "1" appears, you're ready to print.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
