20 Most Recent
E-Machines 19" Widescreen Flat Panel TFT LCD HD Monitor Questions & Answers
I have a yellow vertical stripe on the right side
Check the connectors at both ends; on the screen and on the PC. Make sure they're both properly secured.
If they are, then it may be a faulty cable, or a faulty monitor. It's possible but unlikely to be the graphics card.
About 2 inch yellow stripe appears on the LCD screen
This typically is a sign of either a problem with the monitor itself, the cable, or the computer.
Fault isolation is key here. If you have access to another monitor, I would suggest connecting that to the computer, or vice versa. That way you can figure out what's broken.
If it's the computer, you might be able to purchase a replacement video card. If it's the monitor - you're out of luck, and likely need to purchase a new one.
I have a E machines 19
Open the monitor, examine the circuit boards. Look for small components that look like small cans, these are capacitors. If you see any that look bulged on top, then your problem can probably be solved by replacing these. Check out the following sites;
http://www.youtube.com/watch?v=9Q6_TgNJvQw
Follow the directions and good luck!
I have installed an E181HV on an old dell desktop
This occurs when a generic video driver was installed or the wrong video driver was installed.
You can download the drivers from Dell WEB site, the support download page. Make sure you select your model desktop or laptop, better still, type in the Service Tag number, it is printed on the label on the bottom of the laptop and on the back or sides of a desktop. (If the Service Tag label is missing then go into the BIOS setting and on one of the BIOS pages, the Service Tag number will be displayed). This will open the page where the specific drivers for your model computer are located. Also make sure you select the Windows XP or Vista version of the drivers for your Windows operating system. Click on this link to download the drivers: -
http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
Screen comes on ,then shuts down.(light is blue
Hi
Please try the following, go into safe mode (power on PC repeatedly hit F8 until a menu is presented choose safe mode
Once in safe mode Click the following
Start>Control Panel> System> (Tab) hardware > Device manager
Click on the small + next to display adapters, right click and click on the VGA card and click uninstall, the PC will ask you to restart follow the instructions through and hopefully all will be working
Please can i ask that you leave feedback and vote if this has been useful
