20 Most Recent
Frigidaire FAC126P1A Compact II 12,000-BTU Room Air Conditioner with Electronic Controls Questions & Answers
Frigidaire refrigerator not cooling
You might be blessed.
Try to get down under the machine, like in the back, and see if you can see the compressor.
Compressor is roughly the size of a cantaloupe.
If so, first clean that area well.
Then, look for a pair of parts that are attached to the compressor about the size of your fist.
This should be a pair of electrical switches, one of which is called a "Klix-on".
With your machine plugged in and turned on, most carefully tap that Klix-on with a hammer a few times and see if the compressor starts.
If it does, replace it.
I bought one here in Orlando for less than $40.
God bless your efforts.
A/C remote control K-218E CHUN GHOP10ZB61465 how to program it to a frigidaire 6000btu window unit a/c
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts.
10/16/2016 10:11:55 AM •
Frigidaire...
Answered
on Oct 16, 2016
