20 Most Recent
Hughes HRMC-8 Satellite Remote Control Questions & Answers
How do i program hughes remote using codes list
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily...
http://electro-medical.blogspot.com/
Teac cd receiver sl d80
Try ebay; if not there keep trying - sooner or later someone out there will have one for sale. Just be patient and enjoy the exercise till you get the replacement!
I have a Hughes HTL-HD
check first the main power supply which is AC line get the voltage reading.if it is right check the plug of your Hughes HTL-HD receiver so if the problem is still going on, check the power supply section.
I need to program my
Remote codes for Sony TV are as follows...
001, 085, 126, 166, 079
Click
HERE to download Instruction Manual of HRMC-5, please check page 8-2 for remote codes in manual.
Thanks.
Pixelating & freezing of picture
Hi, Pixelating and freezing are symptoms of loss of signal. You need to check all of your connections. Check for water in any connection. Check your satellite signal strength on each satellite and if low or they are all not there you could have a bad LNB but you need to check the LNBs and the multiswitch for poor or bad connections. Also check for any obstructions in the dish view to the sky or for anything that may not have been tightened down on the dish. Snow and ice builtup will cause this problem as well. Good Luck! Let me know what you find.
How to remove child lock from BELTEK TV?
general steps:
Get the TV remote control and push the "Menu" button and select "Options".
Select "Child Lock" from the "Options" list. On some televisions, the "Child Lock" is named "V-chip".
Choose the "Remove Child Lock" selection. Highlight this and then hit the "Enter" button.
Enter the four-digit code that you used when you activated the child lock feature. If you cannot remember it, your only option to deactivate the child lock is to reset the TV. The instructions for resetting a TV is written on the user's manual of the TV.
Exit the TV menu once you have entered the four-digit code. To do this, press the "Exit" or "Menu" button on the TV's remote control.
If you don't have a remote, you might try leaving the TV unplugged overnight. Some TVs will 'forget' their settings if left without power for a long period. You could also potentially buy a cheaper universal remote, and use that to turn off the child lock.
How to pairing Ruwido Amadeus R 9710 to tv?
To pair your Ruwido Amadeus R 9710 remote to your TV, you can follow these steps:
Insert Batteries: Your remote is powered by two 1.5 V AAA batteries1. Make sure to insert the batteries correctly.
Switch on your TV: Ensure your TV is turned on.
Press the TV key: Press the TV key on your remote control for approximately 4 seconds until the LED flashes twice.
Enter the Code: After seeing the 2 flashes and within 5 seconds, enter the 3-digit numerical code from the list provided with your remote2. After entering the code, the LED will flash twice indicating that the code has been accepted.
Test the Remote: Point the remote control towards your TV and press the key. If your TV does not respond by going into Stand-By mode then repeat steps 3 to 5 and enter the next code in the list.
Bed.-Anl. H2 Version1 (ruwido.com)
