20 Most Recent HP Photosmart 5520 e-All-in-One - multifunction printer / copier / scanner color Questions & Answers
HP Photosmart 5520 wont print when pc is connected to router through ethernet and printer wireless
Have you tried a cold re-boot on printer PC and router worth a try first then check all are on-line and communicating Can you use the PC without the Ethernet cable or a direct cable to the printer just to set it up (Re-set up). Regards David, more info may help all the bests. Ps. my old HP is a pig at time but I never have to use the cable which is a good job as I can never find the thing...
12/25/2017 12:10:24 PM • HP Photosmart... • Answered on Dec 25, 2017
Improper shutdown message and carriage does not move at all.
Hi Tom Speer I would be happy to assist you with your Photosmart 5520 printer. I understand you are seeing an improper shut down message and the carriage will not move. Although you may not be seeing a carriage jam message, you might find the following document helpful: Carriage Jam Message Displays for HP Photosmart 5520 All in One and HP... If the issue persists, I suggest calling us. What you can do, is use the following link to create yourself a case number, then call and it may help speed up the call process: Step 1. Open link: h22207 www2 hp com Step 2. Enter Product number or select to auto detect Step 3. Scroll down to "Still need help? Complete the form to select your contact options" Step 4. Scroll down and click on: HP contact options - click on Get phone number Case number and phone number appear. I hope this helps. I work on behalf of HP.
7/3/2015 6:10:56 PM • HP Photosmart... • Answered on Jul 03, 2015
Printer does not complete print run
for last chance, if u are ussing refurbished ink cartridges,use originals.but not for sure it`ll worked!
4/10/2015 11:51:24 AM • HP Photosmart... • Answered on Apr 10, 2015
Printing very slow and black ink Looks off color
what you do with any inkjet is take all the carts out so you eject the carts position then remove the mains so its stays in park slide a bit of sugar paper {blotting paper} under the cart head then put a large bit of cotton wool into the colours cart housing and soak it through with 30-50mL of IPA from the local chemist and then fold it all shut and place a damp towel over the printer too let it all soak in then once you remove the cotton and put new carts it will work most printers have a soak away for old ink if you have an inkjet you have well used and well then replace it with a modern 70 quid all singing all dancing model so repair with IPA or replace with new i prefer colour toner ...laser prints
3/26/2015 10:07:39 PM • HP Photosmart... • Answered on Mar 26, 2015
Control panel does not work how do I turn it on?
Press Cntr Alt Del and see what is hamming your PC or using the highest Of Cpu, as a last resalt, fully restart your mashine,, that should fix your problem. Good luck, Tony :))
3/2/2015 4:13:46 AM • HP Photosmart... • Answered on Mar 02, 2015
Insert ink cartridges? how to
Easy, you open the cover, remove the old one, remember which way it was inserted if you are not very technical, and insert a new one same way. Just make sure you hear a click, when it fully inserted. Good luck
3/2/2015 3:22:35 AM • HP Photosmart... • Answered on Mar 02, 2015
Install an ink cartridge for photosmart 5520 e-all-in-one series
If you have and running a full software suit for that printer on your PC, than just go thrue that, and follow the instructions. It real easy.. Good luck
3/2/2015 3:14:17 AM • HP Photosmart... • Answered on Mar 02, 2015
My printer is missing several lines each time
generally speaking this is a cartridge problem - some nozzles are clogged - U need to find tools in the printer menu then find clean printhead and run the process and print the test page or print quality page. and keep doing it 2 or 3 times untill the quality is OK - If still no good after all of this U can try soaking the printhead in 1/4" of warm water for 15 minutes and try again - if you are using original HP cartridges you are pretty much done at this point - if you are using refilled or aftermarket cartridges try replacing the black cartridge (I am assuming this is giving you the problem described) with a new HP (buy the small one just in case it still doesnt work) oif you have a cartridge refill place nearby U cant check and see if they can physically clean the printhead for you but results are not always good
2/12/2015 5:41:36 PM • HP Photosmart... • Answered on Feb 12, 2015
How do i find where to enter my printers claim code
you need to contact customer support at HPCONNECT
2/12/2015 2:08:11 AM • HP Photosmart... • Answered on Feb 12, 2015
It says can only print from aps--but will not print
I will suggest to delete all the drivers and any info from your printer out of the computer, after you that unplug your printer from the computer , remove the power cords from the printer then go to HP support page make sure is the official page if you see a page with AD yellow color next to it is not the official. Look for the must currently drivers for your printer and download them then install them. when you confirm that you have them correctly installed turn off your computer and reconnect everything back from your printer and follow the instruction; let me know how goes please.
9/29/2014 1:07:07 AM • HP Photosmart... • Answered on Sep 29, 2014
Why wont my printer let me print off my work
Generally speaking when I see this message I just hit OK and it goes ahead and prints and everything shows up without being cut off - I am in the ink business and my test page shows this message all the time but its not an issue if you press OK and part of ther page is cut off you eitherr need to expand your margins or make the content fit the page
9/16/2014 8:12:29 PM • HP Photosmart... • Answered on Sep 16, 2014
Printer driver
Go to HP.com. At the topof the page select "SUPPORT", then "DOWNLOAD DRIVERS". In the FIND MY PRODUCT block, enter "5520" and click the "GO" button. Scroll down the list until you see your device, click on it. Then select your OS from the drop-down window and download the driver.
8/26/2014 1:34:07 AM • HP Photosmart... • Answered on Aug 26, 2014
Using hpprinter & Win Vista 8.1
If your printer is a duplexer (prints on both sides automatically) u need to set that in the printer properties when U start to do the print job. If its not a duplexer U need to set it up for manual duplexing and follow the instructions
8/8/2014 5:19:12 PM • HP Photosmart... • Answered on Aug 08, 2014
HP Photosmart 5520 e-All-in-One - multifunction printer / copier / scanner color Logo
Popular Tags
70 questions posted
k24674
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
  • HP Office Equipment & Supplies
Most Popular Question
user manual hp photosmart 5520
  • Office Equipment & Supplies
