20 Most Recent Westinghouse Used Original RMT-16 Remote Control Questions & Answers
2answers
How to obtain code for ATSC tuner activation for westinghouse LD2240
  1. activation code 6160y04401296
3/20/2024 3:26:41 PM • Westinghouse... • Answered on Mar 20, 2024
2answers
Cual es el codigo de acceso para canales de tv LD-2240
C?digo de acceso para tv westinghouse, modelo LD-2240 , num de serie :6610120103391
2/25/2024 8:34:27 PM • Westinghouse... • Answered on Feb 25, 2024
3answers
I need the 5-digit code for a Westinghouse TV
This code worked for me Code: 31415
1/12/2024 1:24:52 AM • Westinghouse... • Answered on Jan 12, 2024
2answers
Can I get codes that can reset my old Westinghouse smart tv
Yes, you can reset your old Westinghouse smart TV by using reset codes. The specific code you need may vary depending on the model of your TV. Here are some general steps you can follow to reset your Westinghouse smart TV using reset codes:
  1. Press the power button on your TV to turn it on.
  2. Using your TV remote, press the "Menu" button and navigate to the "Setup" or "Settings" menu.
  3. Look for the "Reset" option and select it.
  4. Enter the reset code for your TV when prompted. The reset code may be a sequence of numbers or a combination of buttons on the remote control.
  5. Follow the on-screen instructions to complete the reset process.
If you don't know the reset code for your Westinghouse smart TV, you can usually find it in the user manual or by contacting Westinghouse customer support. Keep in mind that resetting your TV will erase all custom settings and restore the TV to its factory default settings
1/6/2024 10:03:36 PM • Westinghouse... • Answered on Jan 06, 2024
Westinghouse Television Code. I am trying to get a activation code for my Westinghouse tv remote.
The are two types of code. One to activate the television, or a Universal remote code. FYI, no one uses Universal Remotes in 2023/2024. https://www.google.com/search?q=activation+code+for+westinghouse+tv+remote https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote ..
12/30/2023 8:16:26 PM • Westinghouse... • Answered on Dec 30, 2023
Necesito codigo de tv westinghouse modelo vr4030 para programar canales digitales
necesito. C?digo. De. Acceso. Para. Tv. Westinghouse. Modelo. Uw40t3pw. Serie. 6590y21603173
12/1/2023 12:39:38 AM • Westinghouse... • Answered on Dec 01, 2023
Would like to know what the code is to program my GE universal remote to my 2008 Westinghouse model number ltv-37w2hd
Be sure to manually turn on the device you wish to control. Press. And hold the setup button until the red indicator light remains on and then release the button. Press.
11/1/2023 6:08:28 AM • Westinghouse... • Answered on Nov 01, 2023
Looking for a replacement interior or complete panel for a Westinghouse Cat. NO B20 1632CGT Panel
Only 1 left!
Westinghouse B20 1632CG 200 Amp 120/240V 1 Phase 3 ...
S&S Electrical Supply https://www.sselectricalsupply.com > en-ca > products Westinghouse B20 1632CG 200 Amp 120/240V 1 Phase 3 Wire Indoor Enclosure 22 Space 28" x 15". Save 0. Westinghouse. filler. 1 In Stock / 0 Sold. Style: Used.
10/30/2023 12:05:10 AM • Westinghouse... • Answered on Oct 30, 2023
How do you reset a westinghouse tv?
You can refer to this blog post. It is in detail and very helpful. https://smarthomehut.com/how-to-reset-westinghouse-tv/
4/8/2023 9:37:24 PM • Westinghouse... • Answered on Apr 08, 2023
Half of screen darker on Westinghouse tv
A model would have been beneficial, guessing you have half the LED strips not lighting but it's just a guess without the model
3/29/2023 9:49:43 PM • Westinghouse... • Answered on Mar 29, 2023
5answers
I need a channel access code for a Westinghouse model VR5535Z
try this... Contact westinghouse Channel Access Service by: web: www.westinghousedigital.com/support; select Channel Access and enter Access info. Text Message: Text Tuner to 95495 Phone:1-800-701-0680 follow instructions
2/19/2023 1:45:41 AM • Westinghouse... • Answered on Feb 19, 2023
2answers
Westinghouse WD55UW4620 no picture
Before you replace the power board, there are a few things you can try to troubleshoot the issue with your Westinghouse WD55UW4620 TV:
  1. Adjust the picture settings: It's possible that the picture settings on your TV have been accidentally adjusted, resulting in a dark picture. Try going into the TV's menu and adjusting the brightness, contrast, and other picture settings to see if that helps.
  2. Check the backlight: The backlight is responsible for illuminating the pixels on your TV screen, and if it's not working properly, it can result in a dark or dim picture. You can check the backlight by shining a flashlight on the screen and seeing if you can make out any images. If you can see images, then the backlight is likely the issue.
  3. Check the cables: Make sure that all the cables connecting your TV to external devices are securely plugged in and not damaged.
If none of these troubleshooting steps work, then it's possible that the power board is the issue. In that case, replacing the power board may fix the problem.
2/16/2023 1:04:55 AM • Westinghouse... • Answered on Feb 16, 2023
Backlights on Westinghouse WD50UC4300 TV flash and then go out.
It's possible that there is a problem with the protection circuit, especially if the backlights are receiving the correct voltage but are still not functioning properly. You could try checking the fuses or diodes on the circuit board that are responsible for protecting the backlights. It's also possible that there is a problem with the power supply or the main board that is causing the issue. If you're not comfortable working with electronics, it may be best to consult a professional for assistance.
2/14/2023 3:15:45 AM • Westinghouse... • Answered on Feb 14, 2023
Pass code for channel search on a Westinghouse tv model VR 4090
Hi, pass code's are typically setup by the user that sets up the tv. So, you could start my talking with that person first. If that person is not available, then you might need to factory reset your tv and setup it up again, provide the code to the tv and then write the code down (or email it to yourself) so you'll have it for future reference if you need it. Thank you.
2/2/2023 9:04:22 PM • Westinghouse... • Answered on Feb 02, 2023
2answers
Codigo de acceso televisor westinghouse para modelo cw40t6dw serie 6872w21601344
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily. http://homenol.blogspot.com/ http://remotesearch.blogspot.com/ http://electronicshelponline.blogspot.com/ http://electrohelponline.blogspot.com/ Programming Notes • If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote. • Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality. This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device. Search the site by type in the "brand name" to your device; to which you want set-up codes; in the "Search box at the top right of the display window" to get gathered related posts. /////
1/5/2023 8:42:06 PM • Westinghouse... • Answered on Jan 05, 2023
Why does my Westinghouse television backlight is only strobing behind the screen?
Sounds like the LED strips need replacing. You can get them from ShopJimmy dot com However, this is my standard advice, but since you got the back off https://www.fixya.com/support/r29790007-repairing_own_television ..
1/2/2023 6:18:38 PM • Westinghouse... • Answered on Jan 02, 2023
2answers
Tv flickering WR50UT4009?
Hi, I'm not sure if it's due to the timing unit but the steps that I recommend could help overcome the issue.please run a channel scan on your tv. If still having the flickering issue, please ensure that you have not accidentally increased the FPS setting for your tv. Otherwise, you can remove any accessories attached to the tv and then power cycle the tv. Thank you.
12/9/2022 2:10:02 AM • Westinghouse... • Answered on Dec 09, 2022
Westinghouse Used Original RMT-16 Remote Control Logo
1 questions posted
Top Westinghouse Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Westinghouse Televison & Video
Most Popular Question
need 5 digit code westinghouse tv
  • Televison & Video
