20 Most Recent
Hitachi 23 Cu.ft R-W660 660L Capacity Refrigerator FOR 220 VOLTS Questions & Answers
I have bose 401 speakers and need them to work
Amps don't 'put out' 8-ohms; they're spec'd to drive a nominal load, usually 8-ohms, and always have some leeway as speakers are reactive loads that will vary with frequency.
You need to evaluate what your amp can do with a nominal 4-ohm load. The manual says they will work with amps rated for 4-8 ohm loads. Plug them in and keep an eye (and ear) out for any sign of stress (heat, distortion, smoke) when driving them hard.
7/21/2011 2:25:52 AM •
Hitachi...
Answered
on Jul 21, 2011
I have a Hitachi AX-M131.U.
Download and install CD Burner->click
hereStart the application and select Audio Disc -->click OK.
Drag and drop files ...and click burn.
Select burn speed 24x.
4/6/2011 12:29:39 PM •
Hitachi...
Answered
on Apr 06, 2011
How do I interupt drive power on a J100-A IGBT
That is not a very clear question. When you say interupt drive power,d o you just want to stop the drive? or do you want to render it safe to work on. To stop the drive removing the drive command signal is fine. or look at the wiring diagram and connect some type of stop button. The drive will stop in whatever mode you programmed it for (coast, braking etc) To render it safe for somone to work on it would require a lockable disconnect switch that can be locked in the open position with a padlock (standard fusable or nonfusable disconnect) If you don't have your manual, you can download one here:
http://www.inverter.co.uk/applications/hitachi.htm
7/12/2010 1:52:47 PM •
Hitachi...
Answered
on Jul 12, 2010
