20 Most Recent
iLive Bluetooth Speaker System Questions & Answers
My speaker does not connect to my ipad
The speaker has to be paired with your iPad before it will work. Check your documentation on how to put your speaker in "discoverable" mode long enough for the iPad to find it. If you have previously paired your speaker and it at one time did function is your iPad, make sure that Bluetooth is turned on on the iPad. Also, check the batteries on the speaker if it has previously functioned with your iPad...
How to connect to computer
I do not have a solution...i have a problem. I do not want to hear my music through my phone i want to hear the music on my computer. How do i connect the IHB23B BlueTooth system to play on my computer? thank you
Can I use only 1 speaker ilive ISBW2113B speaker
Yes, you can use only one iLive ISBW2113B speaker. The iLive ISBW2113B is a Bluetooth speaker that can be used individually or paired with another speaker for stereo sound. If you prefer to use only one speaker, you can connect it to your audio source via Bluetooth or using a wired connection, depending on the available options on the speaker. Keep in mind that using only one speaker will result in mono sound instead of stereo sound. However, the single speaker will still be functional and able to play audio on its own.
Can I use only 1 of my ilive ISBW2113B SPEAKERS
Yes, you can use only one of your iLive ISBW2113B speakers. The iLive ISBW2113B is a Bluetooth speaker that can be used individually or paired with another speaker for stereo sound. If you prefer to use only one speaker, you can connect it to your audio source via Bluetooth or using a wired connection, depending on the available options on the speaker. Keep in mind that using only one speaker may result in mono sound instead of stereo sound.
