20 Most Recent Dacor Preference SGM365SS Gas Cooktop Questions & Answers
Need to access the burner controls from underneath the top panel
visit manufacturers web site and click on support and enter model number
12/8/2017 2:59:04 PM • Dacor Preference... • Answered on Dec 08, 2017
Gas burner control stuck
They are not that hard to replace and you can easily buy the part online...
Here is a tip about how to buy appliance parts online.
How to Buy Appliance Parts Online
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
heatman101
1/7/2015 9:51:29 PM • Dacor Preference... • Answered on Jan 07, 2015
2answers
Propane to Natural Gas Conversion
on the regulator there is a 1/2" nut, made of aluminum. loosen the nut, thur it around and screw it back in, there is a "NAT" on one side, and a "LP" on the other side, make sure the "LP" is facing out if you are using propane, and "NAT", if you are using Natural Gas. Very simple, all you need is a 1/2" wrench, or a small adjustable wrench,
2/19/2014 3:12:17 AM • Dacor Preference... • Answered on Feb 19, 2014
3answers
Dacor gas range igniter clicking
I did have the same problem after the house keeping people done with cleaning. They used window/surface cleaner. First I asked them not to clean the ignitor with any cleaner. Here is what I did to solve the problem
I took scotch scour pad (one that you use for washing dishes), In dry state I polished ignitor switch. It is abrading the residuals and deposits on the top and polishing it. Don't use any thing more abrasive than that. MAGIC - I don't have any more problem.
11/17/2013 11:50:09 PM • Dacor Preference... • Answered on Nov 17, 2013
Need to switch a Dacor Gas stove from Natural Gas
an lp gas supplier may be able to help you-check the phone book-cheers denny
10/30/2013 3:44:21 AM • Dacor Preference... • Answered on Oct 30, 2013
2answers
Hi I am trying to convert my Dacor stove/oven from
Hi, to convert from NG to LP is easier in some ways but harder in others. The pressure part is easy because LP runs at the same pressure that comes into the house so the regulator is normally locked wide open to allow a direct by-pass. You could just as easily remove the regulator and plumb straight in from the houseline. You don't say what model but usually the sealed cooktop burners will need smaller orifices and the oven and broiler orifices are adjustable. If that is the case, the oven and broiler orifices can be tightened until they bottom out which be the correct output for LP. You would need to remove the cooktop orifices and find replacements which are correct for LP, these are non-brand specific. Honestly, if you go to repairclinic.com and enter the brand and model number, I'd be surprised if you couldn't find the conversion kit. Even the Dacor site should be helpful. I found many different kits available at the repairclinic.com site even without a model number. Best of luck.
10/9/2013 6:26:38 AM • Dacor Preference... • Answered on Oct 09, 2013
0answers
When front right burner is
The igniter has a switch inside the valve that you turn the gas on. The switch is not opening back up when the stove lights. You will have to replace the valve.
10/5/2010 6:08:38 PM • Dacor Preference... • Answered on Oct 05, 2010
Gff
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
9/5/2010 2:54:59 AM • Dacor Preference... • Answered on Sep 05, 2010
When any of the 4 cooktop burners is turn on to a
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
8/30/2010 12:31:51 PM • Dacor Preference... • Answered on Aug 30, 2010
Hello We recently remodeled our ktich
I googled the problem to make sure I remembered how they worked.The only problem that would cause regulator leak is improper adjustment on a brand new one if the pressure is too high.It also talks about the spring which helps regulate the gas may lose its springiness,after several years though.There are numerous safety measures to stop the gas from coming out if you have a pilot light and it goes out which I did already know.I also know that NEVER will a regulator just simply release the gas into the air from overpressure.That would not even be allowed by anyone in the entire industry.Also,when your drawer is closed,then you open it,do you get a little whiff of gas?Natural gas(is that what you have?) does not have an odor in it's natural state.After it is drawn,a chemical is added so you can smell it and tell if there is a leak.If the odor is very minimal,it may just be the pilot burning if you have one.I would say it would likely be consistent if there was even the smallest of leaks.I used to repair gas appliances however...I was born with no sense of smell.I am including a link to you so that you can learn a little more about gas regulation.Also,I would be persistenet with your plumber and ask him to come over and do a checkup,and just tell him you are very worried about the situation since it could have obviously dangerous results,and it will give you peace of mind.They should do it for free,they better.Tell him you just want him to come over and make a quick gas reading.Hope this helps you out.If you have any questions about what you are reading,I know how all that stuff works,is designed,or whatever.
Just comment to this post and I will get an auto link.
Good luck! Greg
http://www.inspectapedia.com/plumbing/GasRegulators.htm
8/25/2010 8:46:36 PM • Dacor Preference... • Answered on Aug 25, 2010
R rear burner not sparking
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
8/18/2010 11:44:32 PM • Dacor Preference... • Answered on Aug 18, 2010
All gas burners have a
time to clean all the passage way of the gas specially the regulator replace it if cleaning dont work,,thanks hope this helps!
8/10/2010 1:34:02 AM • Dacor Preference... • Answered on Aug 10, 2010
Ignitors clicking
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
7/17/2010 12:24:50 AM • Dacor Preference... • Answered on Jul 17, 2010
After cleaning one of the small burners will spark
make sure the little hole right by the ignitor isn't plugged.
6/16/2010 4:42:11 AM • Dacor Preference... • Answered on Jun 16, 2010
Dacor Preference SGM365SS Gas Cooktop Logo
54 questions posted
Top Dacor Cooktops Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Dacor Cooktop Expert? Answer questions, earn points and help others
View Most Popular
Dacor Cooktops
  • Dacor Cooktops
Most Popular Question
propane natural gas conversion
  • Cooktops
