20 Most Recent
AMP (219560-5) Questions & Answers
Immeadiatly shuts down
First disconnect the speakers and check if the amp. stays on.If don't your audio amplifiers IC's are in bad conditions.Good luck.
Speakon cable to amp
Check the wire's insulation for ridges or striping; if the insulation is clear check the color of the wire inside. Then check the source of the wire to determine which polarity is connected to which wire. Once you know the polarity of the wires at the source, it should be easy to determine the polarity of the wire at the destination. The wire closest to the particular banana clip is most likely the one connected to it. If all else fails, you could use an OHM meter.
