20 Most Recent
Dodge 2002 Ram 1500 SLT Questions & Answers
1994 dodge spirit. Shifted cable
The shift cable on a 1994 Dodge Spirit connects the gear shift lever to the transmission, allowing the driver to shift gears. If the cable is damaged or worn out, it may need to be replaced. Here are the general steps to change the shift cable on a 1994 Dodge Spirit:
- Park the car on a level surface and set the parking brake.
- Locate the shift cable where it connects to the transmission. It will be on the driver's side of the vehicle, near the front of the transmission.
- Use a pair of pliers to remove the cable retaining clip or nut that secures the cable to the transmission.
- Trace the cable up to the gear shift lever inside the vehicle.
- Remove any trim pieces or panels that are blocking access to the cable connection at the gear shift lever.
- Use a pair of pliers to remove the cable retaining clip or nut that secures the cable to the gear shift lever.
- Remove the old shift cable from the vehicle.
- Install the new shift cable by first attaching it to the gear shift lever and then connecting it to the transmission.
- Secure the cable to the gear shift lever and transmission using the retaining clip or nut that you removed earlier.
- Test the new shift cable by shifting through all of the gears to ensure that it is functioning properly.
- Replace any trim pieces or panels that you removed earlier.
Serpintine belt on 2000 dodge caravan needs attaching
I take it you mean installed. The belt sequence for the pulleys should be on the cross member under the hood over the radiator or somewhere in that vicinity. Follow that pattern and you will have to put a ratchet in the front og the belt tensioner to turn it down far enough to get the belt the rest of the way on. Go to youtube and do a search on how to do it. Someone will have a video showing how to do it.
Como cancelar el winter driver
EnglishIt is a car, and cars are complexbut no car was told , maker, model , and year.we can not guess cars. post the VIN? and all that is knownname a problem what can't your car do right?name symptoms or evidence that is confusing to you.then answers can happen.onlygood luck , finding itand Mucho Gusto.my guess now is this is posted to computer forumand not to CARS !must be some odd traction controls thing'but 10,000 models of cars,
I need a product key
Have you actually purchased Visio, or are you just trying to get it for free?
As a software guy, I would have to advise against piracy. :)
There are several ways to get Visio for cheap. If you are a student, there are discounted versions available online and in stores. Also, you can check with your school for even cheaper options sometimes. Try the university bookstore if available. Or a Computer Science department maybe.
If you are working, and your company uses MS Office applications, find out if they have the "Microsoft at Home" program. You can get MS Office applications for really cheap that way. I can get Visio through my company's "Microsoft at Home" program for a few dollars.
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired an
employment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut.
They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
Solitaire master has a hang
clarify pi please. if you meant pi to mean main screen picture, you probably have used up your free time on this program.
