You save to the glide just like a memory stick ,
1 put the glide into a USB on your PC
2 right click on your design and click send to then scroll down to where it says cruzer glide and click on it. ( it may say USB , or removeable memory, you may need to ID what you PC calls it)
your design should be on the cruzer glide!
You can now put it in your sewing machine and follow the directions to sew
you may need to rotate the wheel a little by hand to raise the needle to the top of the stitch position, if this doesn't let the machine acknowledge the pressure foot being raised you may need to power cycle the machine so that it resets.
When you insert your USB stick into your computer it gets assigned a drive letter. Open that drive letter. Now locate the file you want to put on the USB stick . Now click on it to get the drop down menu and clock on copy. Now open the drive letter of your USB stick . Click on the window and choose paste. Your file will then transfer to the USB stick.
Install a brand new needle. Change the type of thread you are using (avoid old thread and bargain bin thread). Quite possibly the thread and needle are incompatible. Here are some guides that may be helpful:
All About NeedlesHow and Why to Bring up the Bobbin Thread
BEFORE threading the upper thread, be sure to RAISE the presser foot. This releases the upper tension disks so the thread will seat properly. Confirm with your owner's manual that you are threading the upper thread in the proper sequence.
Also, may need to adjust the upper tension. Usually, if globs of thread are accumulating under the fabric, the top tension is too loose and/or it is threaded incorrectly. Tighten the upper tension. Correct tension should have the upper thread and bobbin thread meeting in the middle of the fabric.
If there are still issues, there could be a burr or knick in the bobbin area that is catching the upper thread.
check to make sure the top thread is coming off the thread spool ok, sometimes the thread can get caught on the notch that's on the thread spool. also make sure it's moving smoothly thru the top tension area, sometimes it good to use some unwaxed dental floss and use it between the tension disc, always remember where the tension dial was set.
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
As long as you can secure the fabric, you can use a larger hoop. .You can spray baste the back of the fabric, if too small. Do not spray stabilizer when in hoop to avoid a mess. It is less messy to hold fabric over trash can or inside a box. Getting spray on carpet is a disaster!
You have probably solved the problem by now but if not......your bobbin is your problem. Either it is out of adjustment or the bobbin is not woven evenly. Also try to rethread your machine. some of the new machines(I am not familiar with Brother) are very sensitive. Also your manual if you have one should address this problem. If you do not have one go to the Brothers.com they may be able to help. Nancy H. Morris
sounds like the thread is getting caught. Try different thread and change your needle. Some embroidery threads are inferior and shred easily. Needles need to be changed regularly, as they can get burrs.
That sounds like it needs an oiling and clean/tune up. But definitly a servicing. If your like me, you'll be sewing non stop through the holidays. Get it fixed now to prevent problems later.
..... assuming it is the bobbin thread -
Is it the genuine correct bobbin. Has the bobbin has been inserted into the case the correct way ie it is unwinding the correct direction.
Has the bobbin thread been wound onto the bobbin evenly and 'firmly' (not soft or spongy when fingernail is pressed into it) Are there multiple layers of different threads on the bobbin - if so get it all off and wind on only one thread!
Good luck
Pearls often
have very small holes. You need to use a natural silk thread or another very
fine thread. It really depends if you plan to knot between pearls, if so that
will affect your choice of thread, so make sure you get advice from a beading
expert before you buy.
