20 Most Recent
Monoprice 8x6 inches graphic drawing tablet Questions & Answers
Tablet pen cursor moves in the wrong direction
Wow been there my self on my gateway tab also. I found by trying this to be a issue with the FLICKS settings and needed to update the firmware and re calibrate the pen without flicks or other short cuts u might use. Also if u just bought this PEN locally u might contact the seller for assistance and if not able ask to exchange this one to test out if its on your side of the problem or just a issue with this model pen. I often do not try to do to much testing of hardware that might cause more questions and often more problems later. I recommend before u start trying out possible fixes that change the config of now a system that works with 3 pens and has in past what might u change could not help us determine if its your side config or if its a bad pen or is it a known issue and if it is we might beable to at least leave a trail of what we did incase we need to undo what changed.
Please if u could tell us the make of the pens that worked and the make and model of the one that don t... also u might see if anyone else u know could test this pen too on there tab for out ruling works or not.
Good luck ill follow ur posts
Chadman
Como cancelar el winter driver
EnglishIt is a car, and cars are complexbut no car was told , maker, model , and year.we can not guess cars. post the VIN? and all that is knownname a problem what can't your car do right?name symptoms or evidence that is confusing to you.then answers can happen.onlygood luck , finding itand Mucho Gusto.my guess now is this is posted to computer forumand not to CARS !must be some odd traction controls thing'but 10,000 models of cars,
I need a product key
Have you actually purchased Visio, or are you just trying to get it for free?
As a software guy, I would have to advise against piracy. :)
There are several ways to get Visio for cheap. If you are a student, there are discounted versions available online and in stores. Also, you can check with your school for even cheaper options sometimes. Try the university bookstore if available. Or a Computer Science department maybe.
If you are working, and your company uses MS Office applications, find out if they have the "Microsoft at Home" program. You can get MS Office applications for really cheap that way. I can get Visio through my company's "Microsoft at Home" program for a few dollars.
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired an
employment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut.
They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
Solitaire master has a hang
clarify pi please. if you meant pi to mean main screen picture, you probably have used up your free time on this program.
