20 Most Recent
Frigidaire Compact Air Conditioner Questions & Answers
How many btu is this air conditioner model #FAA067P7A
Good Afternoon Friend, this is Z. That's a great question!
I show that your Frigidaire air conditioner FAA067P7A has a cooling capacity of 6,000 BTU's. I hope this information helps to some degree. If you need further assistance, please feel free to reconnect.
Have a frigidare wall ac
The compressor is stopping on overload. There is either a weak breaker or an electrical problem causing the overload to open the circuit and stop the compressor. It has to be taken apart to determine what is or is not going on.
When compressor kicks in the
This appears to be a direct short internally to the compressor . you neede a ohm meter to test it .. not certain how old the unit is but if its a window unit and over 6 years old I would buy a new one. But it does no0t sound good. In the future when a unit trips the breaker and you reset it and it trips right away its best not to trip it again as it contaminate the inside of thye system and is very difficult to clean and expensive as well . those are my thoughts. It could be the outside fan but the way you decribe it tripping right away my money is on the compressor
AC was working perfect before we moved recently.
Depending on how is was placed (Upright, on it's back, or lying flat, as if it was installed) could be the problem. If it was not lying in the same position, as it would be installed, the refrigerant gas ran back into the inner reaches of the compressor and has not returned to where it needs to be.This is usually referenced in the Owners Manual, prior to it being installed the first time. It probably said something to the effect of "allow the unit to sit in the installed position for 8 hours prior to operation". This would allow the refrigerant gas to settle back into place, as well as the oil lubricant in the compressor.
M best advice (Hopefully it's not to late), is turn the unit off for at least 6 hours, to see if everything will settle back into place. If that doesn't solve the problem, you will need to have the compressor professionally recharged. As the existing refrigerant gas will have to be evacuated and captured, before recharging.
Hope this helped you.
Window air conditioner cools but doesn't dehumidify
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
I have a Model #
Once a year you should take the unit out and spray the front and rear coils with coil cleaner and spray it with a water hose. The inside coil gets very dirty on the inside where its hard to see.(where the blower wheel is) The water splashing i condensation not draining to the rear of the unit. The usual problem is the unit not tilted toword the outside enough or the drain whole from the bottom of the front coil is plugged. This whole is only 1/4 inch its small does not take much to plug it. good luck hope this helps.
Our frigidaire window a/c unit
It sounds like your unit is low on freon or the compressor is not kicking in. If the compressor kicks in you can hear it turn the unit on fan only or turn the thermostat off then turn the unit to demand cool you should hear a hum even vibration when the unit kicks in. If there is no audible hum ect... your compressor is probably not kicking in. The selector switch the temp switch the capacitor for the compressor or the compressor its self could be bad. good luck if you need to know how to test any of the above let us know
Timers
go to manufacturer website
Compressor is kicking in but isn't cooling
This problem is related to partial durty in the filter. you can't do that by your self. If you are a technician , :
1. recover the freon,
2. remove the filter;
3. replace by a new one;
4. vacuum the system;
5. charge the freon .
