20 Most Recent Frigidaire FAA065M7A Air Conditioner Questions & Answers
Request the schematic directly from Frigidaire.
Frigidaire... | Answered on Apr 21, 2015
There's something wrong with your aircon. Usually the lights will start to blink. Depending on the brand and model, the number of times it blinks will give you an error code which tells you what's spoilt. You may like to check this out http://www.astiquer.com/blinking.html
Frigidaire... | Answered on Aug 05, 2014
Check the refrigerant charge.
www.frigidaire.com/Customer-Support
Frigidaire... | Answered on Jul 01, 2014
Good Morning Friend,
I understand that the timer light is showing on your Frigidaire air conditioner, model# FAA065M7A, and your appliance will not start. Please press the "hours" button under the timer display. This should stop the timer from showing. If this does not help, I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Hi Junior Flora, this is AP! Thank you for your post.
I understand you are having trouble with your Frigidaire air conditioner compressor not coming back on after it cuts off. There could unfortunately be several culprits causing this to happen. I would recommend unplugging the appliance and letting it heat up to room temperature and try using the air conditioner again. However, if that approach does not prove to be useful you may have a problem with the sealed system, a coil could have frozen over, or the inside of the air conditioner could be getting to cold to operate. I hope this information proves helpful for you.
Frigidaire... | Answered on Mar 17, 2014
Good Afternoon rguyton26, thank you for allowing me to assist you!
I understand you are seeking a wiring schematic on your Frigidaire air conditioner, FAA065M7A post above. I have located the Wiring Diagram, Owner's Guide and etc on the manufacturer website. I hope this information proves to be helpful. If you have any additional questions, please feel free to reconnect!
Frigidaire... | Answered on Sep 10, 2013
Good Afternoon Kate - Thank you for your question! Some air conditioner filters are removed by sliding out from the right-hand side. Others, you need to push the vent handle to the Vent Closed position and open the front panel. Grasp the filter by center and pull up and out the filter can be wash using liquid dishwashing detergent and warm water. Rinse filter thoroughly. Gently shake excess water from the filter. Be sure filter is thoroughly dry before replacing. Keep in mind that instead of washing you may vacuum the filter clean as well. Hope this helps!
Frigidaire... | Answered on May 24, 2013
Air compressor or a can of compressed air.
Frigidaire... | Answered on Sep 21, 2012
If you look thru the front panel just behind it you will see a spong filter. you will need to access it either by removing the front cover or removing the whole front of the unit . wash it in warm soapy water and replace it . let me know
Frigidaire... | Answered on Aug 02, 2012
sounds like the batteries in the thermostat are weak is this a battery powered t stat
Frigidaire... | Answered on May 24, 2012
The rear coil is probably stopped up with dirt causing the valves in the compressor to release. You will have to take the casing off of the unit to clean it properly. Some times, if its not too bad, you can wash it out from the back side of the unit. If you try this you will have to unplug the unit, take a water hose with a sprayer and spray carefully through the back coil. You have the chance of getting the motor wet, so will need to let it dry out a couple of hours after you do this.
The best way is it take the case off. It will have a few screws in it. If it has "wings" on it to make it fit in the window, you will have to take the wings off in order to get the case off. Take the unit out on the driveway, look through the rear fan blade to see the inside of the rear coil. You will probably see dirt caked on to the coil. The coil has a few screws holding it to the fan shroud. Take these screws out. Notice the coil will have two copper lines going into one side. BE VERY CAREFUL NOT to break these lines. After you get the screws out from the shroud the coil will ever so gently be lifted from the unit, copper lines still connected. Just pull the coil out enough to get behind it to clean it out. Put it back together. If should work now. Only other problem it could be would be the compressor valves. If this is the case, unless it is still in warranty, it will not be worth fixing.
Frigidaire... | Answered on Jun 12, 2011
york split ac indor unit no working .timer light is on . how to stope timer control light ?
Frigidaire... | Answered on Feb 20, 2011
Two issues are possible.
First of all check for dirt accumulation that is blocking the water to drip but is diverting to the front panel section to flow into the wall.
Secondly the A/C must be mounted with a slight tilt thereby making the water condensation to flow/drop into the tray. If not you can remove and make a small wedge on the mounting to tilt.
Also use a good air jet or a water jet( if taken out) to clean the coils.
Frigidaire... | Answered on Jan 05, 2011
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Frigidaire... | Answered on Aug 31, 2010
Frigidaire FAA065M7A Air Conditioner Logo
52 questions posted
Top Frigidaire Heating & Cooling Experts
Donni Steen
Bill Long
Pete Norton
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Heating & Cooling
Most Popular Question
check filter light
  • Heating & Cooling
