20 Most Recent Frigidaire FAH085N1T Air Conditioner Questions & Answers
Bad switch or not wired correctly.
Frigidaire... | Answered on Oct 02, 2017
If compressor starts, check the running current of the compressor. If amperage is too high together with the discharge pressure, try cleaning the condenser fins and then after cleaning test the amperage and pressure again. If the pressure is still above the normal operating of 300psi, release some freon. If the discharge is too low below 200psi and running ampere of compressor is below the rated ampere of the unit add some freon from the suction line until it reaches 60-65psi. If still suspicious with the unit, try removing all freon charge and evacuate the system to 30 in. Hg to remove any moisture from the system and hold the vacuum for 30 minutes. If no increase in system pressure, recharge and check pressures and amperage.
Frigidaire... | Answered on Sep 03, 2011
Check for fan blade defect or possibly loose from its shaft.Check for any obstruction in the cooling fins and use a clamp meter to detect the problem.
Frigidaire... | Answered on Aug 31, 2011
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Frigidaire... | Answered on Aug 11, 2011
Did you just buy the unit?
Frigidaire... | Answered on Jul 06, 2011
your compressor motor is no good Time to replace unit
Frigidaire... | Answered on Sep 09, 2010
replace the rtc overload
Frigidaire... | Answered on Sep 04, 2010
Check the filters if clean try cleaning the coils front and back. A hose should do the trick. Just blow through both side try not to bent the fins.
Frigidaire... | Answered on Aug 28, 2010
Get a bubble level and make sure the housing is sloped away from the house and yes remove at least one of the drain hole plugs.
Frigidaire... | Answered on Jul 12, 2010
No you do not. Not a bad option, but if wall sleeve nstalled properly this unit will not need brackets.
Frigidaire... | Answered on May 11, 2010
It should be pretty apparent what comes off the unit. Pop the front cover by the filter and remove any styrofoam, paper and ties that might be there. Also make sure to remove anything that would prevent the coils from breathing properly. Its really simple, dont complicate it anymore than need be and worry yourself, everything that comes out is obvious.
Frigidaire... | Answered on May 02, 2010
Hi!!
I am assuming that nothing comes on in the display.
Check:
power cord for continuity,
power to board, if OK, replace board.
These are the only two things I can think of that can stop compressor and fan from working.
Don't forget to rate this answer, Good Luck!1
Frigidaire... | Answered on Apr 18, 2010
Frigidaire FAH085N1T Air Conditioner Logo
28 questions posted
Top Frigidaire Heating & Cooling Experts
Donni Steen
Bill Long
Pete Norton
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Heating & Cooling
Most Popular Question
need brackets outside wall installation
  • Heating & Cooling
