20 Most Recent
Ridgid 9 Gallon Wet/Dry Shop Vac 96882 Canister Vacuum Questions & Answers
Why does my Rigid shop vac make a high pitched whistle with a long hose on it but not a short hose?
The high pitched whistle that you are hearing from your Rigid shop vac with a long hose may be due to several reasons. Here are some possible causes:
- Airflow restriction: When you use a longer hose with your shop vac, it increases the airflow resistance, which can cause a whistling noise. This is because the motor has to work harder to maintain suction, and the increased resistance can cause turbulence in the airflow, creating the whistling sound.
- Hose size: The size of the hose can also affect the whistling noise. A smaller diameter hose can increase airflow resistance, which can cause the same issue as a longer hose.
- Clogs or blockages: If there are clogs or blockages in the hose, this can also cause the whistling noise. Check the hose and attachments for any obstructions, and remove them if necessary.
- Vacuum motor issue: In some cases, the whistling noise may be due to a problem with the vacuum motor itself. This could be caused by a damaged impeller, a loose fan blade, or other issues with the motor.
To fix the issue, you can try the following:
- Shorten the hose: If possible, try using a shorter hose to see if the whistling noise goes away. A shorter hose will reduce the airflow resistance and may help to eliminate the noise.
- Check for blockages: Inspect the hose and attachments for any clogs or blockages. Remove any obstructions that you find.
- Clean or replace the filter: If the vacuum filter is dirty, this can cause airflow resistance and make the motor work harder, leading to the whistling noise. Clean or replace the filter as necessary.
- Check the vacuum motor: If none of the above solutions work, you may need to inspect the vacuum motor for any issues. If you are not comfortable doing this yourself, you can take the shop vac to a professional for repair.
I have a 6 gall wet dry shop vac bye rigid . do i
Always use the foam filter when using the Shop Vac, keep your filters clean and it will operate more smoothly. When sucking water I usually take the foam filter off as well as the cylinder filter
Dust blowing right back into the air
You need to check the filter and make sure it's on all the way. To do this take the top off the vac, make sure the filter is all the way up and in place. There should be a plastic nut to hold it in place. If you are using it for fine dust particles such as drywall dust, you need a special filter for small particles. The filter that comes with the vac just won't do it!
Can u wash the paper filter on a wet dry vac
You really cannot wash the paper filter. You can blow it out with an air hose if you have access to one, or vacuum it off with another vacuum. If it does get wet you should let it dry outside of the vacuum before you use it again.
