20 Most Recent
HP Pavilion tx1210us Tablet PC Questions & Answers
My HP Pavilion tx1210us Tablet PC just comes on
Sounds like a video problem with the GBA (grid Ball array) The HP pavilion tx series are notorious for this problem. The solder on the bottom of the video circuit crystalizes from the heat (these laptops run hot) and then it doesnt make a good connection. You have to reflow the solder (usually means taking apart or sending to a shop). But I found a quick and easy fix for them, I fixed about a dozen already like this in my shop (I own one too) Turn on laptop..then wrap it in 2 thick towels so it will get hot..sounds crazy, but it works..leave in towels running for about 30 or 40 minutes, then unwrap the laptop, power it off and restart it..bet it works!!!
How do i fix my hp tablet stream7 that has a black screan
You can try a factory reset, try holding the power button and the volume down key on the side of the tablet then use the up and down voulum keys to select factory reset and push the power button. That should bring up a screen that says are you sure? Use the volume keys to select yes and it should reset. If this doesnt work, you have to get ahold of hp customer service.
