20 Most Recent
Panasonic Toughbook-19 Tablet PC Questions & Answers
My monitor display has rotated itself 90 degrees
on the front of the toughbook there are 4 small buttons, the 3rd from the left which has a right angle symbol with a double headed arrow in it rotates the screen 90 degrees each time you press it. this is probably how you got it like that in the first place.
8/23/2012 12:50:02 PM •
Panasonic...
Answered
on Aug 23, 2012
How do you run a battery recalibration
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all.
OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time.
If the battery drops to an unacceptable charge level then the battery needs to be replaced
5/26/2010 3:45:53 AM •
Panasonic...
Answered
on May 26, 2010
Screen is illuminated but blank.
Can you try restarting the Tablet and see if you get a result by tapping the F8 key?..on windows,that will put it into safemode and allow you do fix certain problems...please let me know..will try to get u fixed up
4/15/2010 7:45:17 PM •
Panasonic...
Answered
on Apr 15, 2010
Shut off touchpad
Most pc's use a program named symnaptics touch pad. Go to the control panel, select the mouse tab then mouse properties and device settings (select disable). Here you can disable the touch pad. I would recommend you have a usb mouse up and running prior to doing this procedure (saves tons of headache).
8/7/2009 3:32:14 AM •
Panasonic...
Answered
on Aug 07, 2009
Panasonic fz-g1 dock pinout
Dock pinout is the input power on the tablets, it always in and out process. Recommended to replace whole flexible dock inside the tablet for better quality.
10/15/2013 3:01:16 PM •
Panasonic...
Answered
on Oct 15, 2013
How to install rom on Onn 100011886 tablet go edition.
"rom"? What exactly are you trying to do? Are you referring to ROM as part of the tablet's memory? If yes, you probably will not be able to do it. ROM is a memory chip built onto the circuit board itself inside the tablet. You would need to completely dismantle the tablet to do it. Most tablets are not built to be taken apart for repairs.
4/13/2024 11:56:23 PM •
Tablets &...
Answered
on Apr 13, 2024
