20 Most Recent
Janome Sewist 625e Questions & Answers
Needle up/down button
Check that the bobbin winder on top of the machine is clicked to the left or disengaged.
1952 singer manuel
If you're in the US, contact Singer Customer Support at 1-888-633-8635 Monday through Friday 8AM to 4PM CST.
Where do I oil my machine sewist 625e
Look on machine for little red dots with a small hole nearby. Usually these are near the threading points and also on the foot near or on the metal flap. Also they may be under the flap near the bobbin. Make sure you wipe the excess oil off before using.
Thread a twin needle
The same as a regular needle a twin goes in the same. it has only one stem
notice above the read is on stem this goes into the same area as a regular needle.
When I try to sew
Hello
My first guess is the needle is in backwards; my second is that you're not hanging on to the end of the top thread as you're lowering the needle.
lift the presser foot and pull about 7" of thread through the needle.
Drop-in bobbins collect a lot of lint in the bobbin case and need frequent cleaning. The bobbin thread can sometimes pull out of the guide on the side of the bobbin case.
Last resort - the timing needs to be re-set and this means a trip to the shop.
It is very unlikely a tension problem.
Does a Brother walking (quilting)
More than likely. You mount the walking in place of the regular foot. You just have to attach the fork over the needle clamp screw at the same time.
