20 Most Recent Epson Perfection V200 Flatbed Scanner Questions & Answers
2answers
Scanned pictures has thin blue line running through it
I had the same problem with My Espon Perfection V500. I called tech support and they had me do the following sequence.
1. Turn off the unit
2. Unplug the lid from the base
3. Replug in the lid.
4. Turn the unit back on
5. Go into the Epson software in Professional mode, Configuration, Other and select Reset All
6. Rescan the picture.
It worked after that. Of course it also lost all my preset sizes in my Custom box and any other settings I had. I suspect the lid plug is what the problem was.
Another word to the wise. To test it I put in a picture that was laying on my desk and rescanned it and was disappointed to see the line in the result. A few minutes later I discovered that this particular line was in the original picture.
7/5/2015 4:55:23 PM • Epson Perfection... • Answered on Jul 05, 2015
tip
How to Clean Scanner Glass
Steps how to clean scanner glass
1. Unplug the power cord.
2. Clean the outer case with a cloth dampened with a mild detergent and water.
3. If the document table glass gets dirty, clean it with a soft dry cloth. If the glass is stained with grease or some other hard-to-remove material, use a small amount of glass cleaner and a soft cloth to remove it. Wipe off all remaining liquid.
4. Ensure that there is no dust on the glass of the document table. Dust can cause white spots in your scanned images.
*** CAUTION: Do not press on the document table glass too hard.
5. Be careful not to scratch or damage the document table glass, and do not use a hard or abrasive brush to clean it. A damaged glass surface can decrease the scanning quality.
6. Never use alcohol, paint thinner or corrosive solvent to clean the scanner. These chemicals can damage the scanner components as well as the case.
7. Be careful not to spill liquid into the scanner mechanism or electronic components. This could permanently damage the mechanism and circuitry.
8. Do not spray lubricants inside the scanner.
9. Never open the scanner case.
***NOTE: Wipe the inside of the document cover and the scanner's document table before scanning transparencies.
0answers
2answers
Filmy appearance and spots on the underneath of glass
Today I opened my V200 without much problems. First unscrew the two screws under the lid. Then turn the V200 upside down. Lift the base plate up, gently, beginning at the back (a little twisting is needed). Take care not to force anything. It took me 10 minutes. Fold everything open like a suitcase, then clean the glass inside...
To close again start with the front (sort of click system)
2/10/2013 5:29:25 AM • Epson Perfection... • Answered on Feb 10, 2013
2answers
I bought an Epson scanner
hi,
see the power rating on the power pack adapter. Unless otherwise stated,
most come with an international standard of 220v. I bet you can find an adapter with the right capacity that fits your scanner if that doesn't work.
Hope this helps
pls rate or vote this
7/5/2011 8:43:15 AM • Epson Perfection... • Answered on Jul 05, 2011
I am scanning Kodachrome Transparency's
There are manual position settings you can use.
Make sure the film is placed correctly in the film holder and the film holder is properly
positioned on the document table.
Switch to Home Mode or Professional Mode, and preview with the Normal Preview. In the
Preview window, create marquees on the area you want to scan, and then scan.
Also...if all else fails
Try rotating the slide 90 degrees, you can always rotate the saved image afterwards.Ditto flipping over to the other side
.I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
2/26/2011 6:19:03 PM • Epson Perfection... • Answered on Feb 26, 2011
When scanning slides, the scanner crops the top
Try switching slide position in slide holder. A 90 degree turn might help.
10/23/2010 9:50:29 PM • Epson Perfection... • Answered on Oct 23, 2010
V 300. Scanning transparencies. Worked
Yes, if you can find a replacement lamp. Try your electronic repair shop.
9/20/2010 10:56:09 AM • Epson Perfection... • Answered on Sep 20, 2010
Filmy appearance and spots under glass on Epsom
Operating heat vaporizes some lubrication grease that condenses on the glass. The glass is removable and can be cleaned like ordinary glass.
7/17/2010 7:38:14 AM • Epson Perfection... • Answered on Jul 17, 2010
2answers
Scanning from Photoshop it send me directly to the
Hi
Does your computer notice / detect the scanner? if it does not, then the power supply might not be working or it might not be plugged in, you might need a new powersupply or then the scanner itself might have a fault that prevents it from starting up, try unplugging it for a while and see if it helps, also make sure that the power adapter is the one ment for this scanner, a different adapter that doesn't give out exactly what the scanner requires might damage it.
A new basic scanner doesn't cost much, so replacing parts on this one might be more costly than buying a new one.
12/6/2009 4:48:40 AM • Epson Perfection... • Answered on Dec 06, 2009
Need an Epson A221B 24v AC adapter
The part number is 2115845 if you put Epson 2115845 in your search engine you will get lots of hits for that power supply. Here is a link for an Epson parts distributor. http://www.encompassparts.com/products/?2115845
Hope that helps.
8/26/2009 4:36:26 AM • Epson Perfection... • Answered on Aug 26, 2009
How do I scan a slide photo / negitive on my epson
safemanuals.com/user-guide-instructions-owner-manual/EPSON/PERFECTION%20V200-_E
please go the above link and download the pdf file and you will get a complete pocedure on scanning a photo/negative
8/8/2009 4:51:05 PM • Epson Perfection... • Answered on Aug 08, 2009
3answers
Need Replacement AC Adapter for Epson V200 Scanner
I have an Epson AC Adapter 220volt/13,5 Volt. Model A391VD As my scanner broke down. Fell from my table.
8/5/2009 2:23:11 PM • Epson Perfection... • Answered on Aug 05, 2009
Epson Perfection V200 Flatbed Scanner Logo
53 questions posted
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Perfection Epson
  • Perfection Epson
Most Popular Question
when scanning slides scanner crops top
  • Office Equipment & Supplies
