20 Most Recent Frigidaire 11.2 cu. ft. / 317 liter Commercial Freezer FFU11FK1CW Questions & Answers
I have a Frigidair commercial 11.2 cubic feet it
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
8/15/2010 10:23:26 PM • Frigidaire 11.2... • Answered on Aug 15, 2010
Frigidaire FFU1424DW16 upright freezer. What is the cubic feet of it?
Question edited for clarity and add maker. Question moved to correct category. 16 cubic feet for that series, the '16' in the model number. https://www.google.com/search?q=Frigidaire+FFU1424DW16+freezer+Cubic+feet ..
11/16/2023 3:43:26 AM • Frigidaire... • Answered on Nov 16, 2023
Frigidaire MFC20M4FW3 Freezer. What is the cubic feet of my freezer please?
Question edited for clarity. Question moved from Washing Machines category. It looks to be a standard 20 cubic feet freezer and has '20' in its model number. you can also measure it internally in feet and multiply length x width x depth. https://www.google.com/search?q=frigidaire+mfc20m4fw3+review ..
4/15/2023 6:41:20 PM • Frigidaire... • Answered on Apr 15, 2023
2008 Frigidaire upright freezer giving error code -H9. Can you please help me with this? No notation in manual.
The error code -H9 on a Frigidaire upright freezer typically indicates a communication error between the control board and the display board. To troubleshoot this issue, try unplugging the freezer for a few minutes, then plugging it back in to see if the error code clears. If the error persists, it may be necessary to replace one or both of the boards. Contact a qualified appliance repair technician for further assistance.
2/14/2023 6:48:44 AM • Frigidaire... • Answered on Feb 14, 2023
What is the cubic ft.for a Frigidaire stand up freezer model MFU23BW4
According to the Frigidaire website, the cubic feet for the Frigidaire stand up freezer model MFU23BW4 is 23 cubic feet.
1/6/2023 6:19:01 PM • Frigidaire... • Answered on Jan 06, 2023
2answers
High temp code on my frigidaire upright freezer. What is this and how do I fix it?
Many reasons why it may be loosing temperature. Such as Defrost problem, fan not running, sealed system problem, compressor problem
11/2/2022 6:39:37 PM • Frigidaire... • Answered on Nov 02, 2022
2answers
My frigidaire chest freezer model FFFC07m2kw stopped working and all food thawed inside . we cleaned it out and since when we plug it up it comes on for 5 to 10 seconds and then stops .
if have an amp probe [multi-meter] when turns on check amp draw on motor ----motor failure ---thermostat failure --no freon
8/28/2022 9:00:34 AM • Frigidaire... • Answered on Aug 28, 2022
2answers
My Frigidaire up right freezer is showing an error code "FF" and is beeping. What is the issue?
Hey friend, thanks for your inquiry!
Within your Frigidaire freezer the error code "FF" stands for freezer failure. I would perform a reset on your appliance which can be done by either unplugging the power cord or flipping the household circuit breaker. Once the freezer has come back on you should be able to push the "Down" button three times to start it back up.
If that does not correct the issue Please respond back I would like to assist you with any additional information. Hope this helps to some degree. -Matt
8/7/2022 8:10:40 AM • Frigidaire... • Answered on Aug 07, 2022
I have just defrosted my Frigidaire elite larder freezer. The red and orange lights are on but not the green There is power as I can hear it running
It is under the temperature is has been set to. It should stabilise in about 4 hours..
6/4/2022 3:10:00 PM • Frigidaire... • Answered on Jun 04, 2022
My Frigidaire upright freezer has a big gap on the bottom left corner and the top left corner is hitting the freezer body!
Question edited for clarity. Question moved from Cars and Trucks!! This has all the hallmarks of a fridge that may be overloaded with weight, on an uneven floor with misaligned levelling feet. Cut a piece of 1" marine plywood 1" bigger than the width and depth. Empty the freezer and put it on the plywood. Level the feet using a spirit level left to right and a fore and aft. Make sure it doesn't rock. Loosen the door hinges and centre the door. Fill the freezer back up.
5/25/2022 2:26:45 AM • Frigidaire... • Answered on May 25, 2022
Model FRF170FF. Why is alarm light blinking with no warning bleep?
in settings alarm might be turned off
2/28/2021 10:36:08 AM • Frigidaire... • Answered on Feb 28, 2021
2answers
Frigidaire 13.7 cu ft freezer lost power during a winter storm. Display comes on but not the compressor.
Disconnect the power again for 5 minutes and then put a dinner knife across the two mains plug pins. Then plug it back in. If it doesn't work after that you need an engineer. The main board or other components may have been damaged by a power spike when the power cut.
2/28/2021 10:32:12 AM • Frigidaire... • Answered on Feb 28, 2021
2answers
I TRANSPORTED A REFRIGERATOR FROM HOUSTON TO
sound like the condenser fan motor by the compressor has stopped and the not allowing the proper cooling check that also you should have waited at least 6 hr upright before starting the unit
10/23/2019 10:37:05 AM • Frigidaire... • Answered on Oct 23, 2019
Frigidaire 11.2 cu. ft. / 317 liter Commercial Freezer FFU11FK1CW Logo
3 questions posted
Top Frigidaire Freezers Experts
ZJ Limited
ZJ Limited
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
View Most Popular
Frigidaire Freezers
  • Frigidaire Freezers
Most Popular Question
freezer defrosted did not get cold
  • Freezers
