20 Most Recent Frigidaire 17.8 cu. ft. / 504 liter Commercial Freezer FFC18K1CW Questions & Answers
Try repairclinic.com or partselect.com, they have some good online diagrams and manuals for free.
Frigidaire 17.8... | Answered on Jul 14, 2010
The problem was never solved. I never got to chat with anyone about anything at all, and I dont have a ******* freezer. If I was able to chat with someone I would have been able to get the proper model number from my washing machine.
Cancel my subscription and I want a refund in full. Dont send me any more emails, unless it confirms my subscription is canceled. I will not use your service. Your website is to complicated and is designed to rip people off.
Frigidaire 17.8... | Answered on Feb 15, 2010
your power contactor relay on the compressor body is defective
Frigidaire 17.8... | Answered on Oct 25, 2009
Did you replace the timer? If it got stuck once it will get stuck again. If you did replace the timer, are you sure you connected the wires to the correct terminals? If not you will be in defrost for 12 hr, and cooling for 20 min. (example) Hope this helps
Frigidaire 17.8... | Answered on Sep 30, 2009
The first thing that I would look at is the compressor relay. The relay gives extra windings in the motor, power to get the compressor up to speed. It is a small thing that carrys a heavy load. (MORE)
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Frigidaire 17.8... | Answered on Jul 07, 2009
You have a blockage in your drain tube, at the bottom of the metal tray there is a hole which is connected to a tube which runs down the back of your refridge to a pan next to the compressor. It is an easy fix have done this 1000's times. Remove back panel in freezer, grab a heat gun or hair dryer and melt the ice it the bottom of tray. Clean the water in the tray with some paper towel next get some hot water in a measuring jug and pour into the pan(hot water will help melt ice in tube) repeat this process a couple of times and then get a curtain wire or something flexible to push down the pipe to clean the blockage...you will know when the blockage is clear because the water in the pan will suddenly drain off....put cover back on...make sure to unplug appliance before servicing...hope this helps :)
Frigidaire 17.8... | Answered on Jun 23, 2009
That yellow light on sonne older modelks is just showingbtge power is on. I never heard of a chest freezer having a "quick freeze" feature. This feature would also require forced air cooling and auto defrost. If the walls get frost on ghr m t hen Im betting that is ju st a power light although it may say freeze or something else like that. Its just so when you see the yrllow light you know there is power.
Frigidaire... | Answered 3 days ago
Typically, error code "HI" (the customer may say "H1") on a Frigidaire refrigeratorunit indicates that the unit has detected high temperature in the freezer and/or therefrigerator https://kb3.s2g.net/index.php?/article/AA-00411/0/Frigidaire-Refrigerator-Unit-Flashing-HI.html
Frigidaire... | Answered on Mar 29, 2019
call a repair service or go buy a new one
Frigidaire... | Answered on Feb 22, 2019
Many reasons why it may be loosing temperature. Such as Defrost problem, fan not running, sealed system problem, compressor problem
Frigidaire... | Answered on Jan 18, 2019
Frigidaire 17.8 cu. ft. / 504 liter Commercial Freezer FFC18K1CW Logo
7 questions posted
Top Frigidaire Freezers Experts
AJMAL KHAN
Dennis Boxerman
Bruce Denton
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
View Most Popular
Frigidaire Freezers
  • Frigidaire Freezers
Most Popular Question
run continuosly
  • Freezers
