20 Most Recent
Frigidaire 15 cu. ft. / 425 liter Chest Freezer FFC15C3A Questions & Answers
Need diagram for thermostat for chest freezer
The green wire is a safety ground and will attach to the body of your freezer somewhere not far from the thermostat. It really does not matter where it attaches as long as it is a clean piece of metal. Here is a link to a wiring diagram but it is not showing the green wire.
HEREIf you have questions please let me know, Thanks
Sea Breeze
Unit runs continually with gurgling sounds
defrost fully once a year or more if you notice it frosting up.it should run at minus 18c to 20 c for best results. 0f is fine.gurgling noise is normal (liquid turning to gas before compressor turns it back to liquid).make sure door seals all round and the kids close the door asap after use......also if you portion up food prior to freezing and vacpack it it will last longer.and be easier to store/rotate.
How to defrost
these units should have a self defrost cycle.
or they can be defrosted by turning the off and remove the plugs in the bottom of the unit so the water can be let out.open the lid you can also use a blow dryer to speed up the process.
We have a 21 cu ft 2009 chest freezer. It is not
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Chest freezer not freezing
home refrigeration units are not designed to work in low temperature areas. where temps will drop below 45f so that is your problem. this is listed in your owners manual if you want to verify. thx peyton
My Frigidaire up right freezer is showing an error code "FF" and is beeping. What is the issue?
Hey friend, thanks for your inquiry!
Within your Frigidaire freezer the error code "FF" stands for freezer failure. I would perform a reset on your appliance which can be done by either unplugging the power cord or flipping the household circuit breaker. Once the freezer has come back on you should be able to push the "Down" button three times to start it back up.
If that does not correct the issue Please respond back I would like to assist you with any additional information. Hope this helps to some degree. -Matt
