20 Most Recent Frigidaire 5 cu. ft. / 142 liter Chest Freezer FFC05C2A Questions & Answers
0answers
How tight should the suction be on the door of chest freezer
Hello dotty26 - The door gasket should be securely closing with no resistance. You may try lubricating the door gasket with petroleum jelly to make it easier to open as well.
2/28/2013 6:44:10 PM • Frigidaire 5 cu.... • Answered on Feb 28, 2013
Does not get cold
Hello bprice7777 - When was the last time you cleaned the condensers? You may do so by removing the toe grille and use extended vacuum attachment and condenser cleaning brush to remove dust buildup from condenser coils usually located on the left side underneath. If you hear the compressor running and if it is providing warm air then that means it is operating correctly and the sealed system is removing heat from the cabinet. Fan motor/evaporator may be the primary issue. However, if you do not hear the compressor and the unit is blowing room temperature then the unit may possibly have a sealed system leak, faulty compressor or overload relay. Also try checking and see if the door seal is bad; place a dollar bill between the body of the freezer and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocked by anything stopping it from closing it. If any suggestion proves to be ineffective contact a professional to move forward accurately.
11/15/2012 7:47:52 PM • Frigidaire 5 cu.... • Answered on Nov 15, 2012
We just bought a chest
Most likely it isn't the suction but moisture on your seal freezing to the frame. Suggest a putty knife with a hair dryer blowing hot air on the blade and working it around the seal.
8/3/2011 11:30:45 PM • Frigidaire 5 cu.... • Answered on Aug 03, 2011
Is there an ambient temperature range outside of
It seem ambient temperature will not affect so much inside temperature since any freezer has good insulation. Normally freezer will go down to below zero degree
12/15/2010 8:08:08 PM • Frigidaire 5 cu.... • Answered on Dec 15, 2010
Turned off freezer, because didn't need to use it.
Good day,
If you can hear it running but does no cooling then either you have lost the refrigerant charge, or the system has developed a restriction somewhere in the lines. It will require the attention of a professional.. If the machine is under 5 years of age, then the factory will cover the repair.
Call your selling dealer for a warranty repair.
11/12/2010 2:58:49 PM • Frigidaire 5 cu.... • Answered on Nov 12, 2010
There's an electrical short circuit inside that
youneed teast equipment like a volt ohm meter to start truely i think you should have a pro out to see if your compressor did not burn out
9/20/2010 4:52:07 PM • Frigidaire 5 cu.... • Answered on Sep 20, 2010
My freezer shuts off
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
5/2/2010 7:17:22 PM • Frigidaire 5 cu.... • Answered on May 02, 2010
Not getting Cold
Good day,
You didn't say if it runs. The machine when it does run is still very quiet. With it on, if you can hear it running. You may have to put your ear up to the machine. If so, then in the move you caused a refrigerant leak. The leak could be anywhere in the machine including areas that cannot be reached.
If however, they are lines that run on the outside of the machine, they can be repaired by a qualified tech, but the repair would be pricey.
If it is not running, I would check around the compressor area for a wire that was knocked off.
4/2/2010 9:57:03 PM • Frigidaire 5 cu.... • Answered on Apr 02, 2010
Frigidaire uprite freezer won't cool
it's scrap
they use steel lines inside the cabinet and when you unplugged it the lines rusted through
7/30/2009 3:06:14 AM • Frigidaire 5 cu.... • Answered on Jul 30, 2009
Frigidaire Mod FFC05C2AW1 freezer won't cool, hear
please switch off your refrigerator for at least 5 hrs. than again switch it on. if your problem is not cured than it is sure that you have your gas chockage....... please visit your service authority
5/14/2009 10:33:51 AM • Frigidaire 5 cu.... • Answered on May 14, 2009
Freezer not working
compressor is faulty. clicking noise you hear is the overload for the compressor. not worth repair and not diy
7/2/2008 11:24:08 PM • Frigidaire 5 cu.... • Answered on Jul 02, 2008
Kenmore Upright Freezer Model 2539252110
constant clicking, sounds like a compreesor trying to start itself, you might geta way with replaving hte starting device for compressor, sometime s a bad compressor will burn out a starting device, checl your warr papers, most compressors had afull 5 year warr
3/18/2008 1:52:40 AM • Frigidaire 5 cu.... • Answered on Mar 18, 2008
Frigidaire FFU1424DW16 upright freezer. What is the cubic feet of it?
Question edited for clarity and add maker. Question moved to correct category. 16 cubic feet for that series, the '16' in the model number. https://www.google.com/search?q=Frigidaire+FFU1424DW16+freezer+Cubic+feet ..
11/16/2023 3:43:26 AM • Frigidaire... • Answered on Nov 16, 2023
Frigidaire MFC20M4FW3 Freezer. What is the cubic feet of my freezer please?
Question edited for clarity. Question moved from Washing Machines category. It looks to be a standard 20 cubic feet freezer and has '20' in its model number. you can also measure it internally in feet and multiply length x width x depth. https://www.google.com/search?q=frigidaire+mfc20m4fw3+review ..
4/15/2023 6:41:20 PM • Frigidaire... • Answered on Apr 15, 2023
2008 Frigidaire upright freezer giving error code -H9. Can you please help me with this? No notation in manual.
The error code -H9 on a Frigidaire upright freezer typically indicates a communication error between the control board and the display board. To troubleshoot this issue, try unplugging the freezer for a few minutes, then plugging it back in to see if the error code clears. If the error persists, it may be necessary to replace one or both of the boards. Contact a qualified appliance repair technician for further assistance.
2/14/2023 6:48:44 AM • Frigidaire... • Answered on Feb 14, 2023
What is the cubic ft.for a Frigidaire stand up freezer model MFU23BW4
According to the Frigidaire website, the cubic feet for the Frigidaire stand up freezer model MFU23BW4 is 23 cubic feet.
1/6/2023 6:19:01 PM • Frigidaire... • Answered on Jan 06, 2023
Frigidaire 5 cu. ft. / 142 liter Chest Freezer FFC05C2A Logo
Popular Tags
22 questions posted
Top Frigidaire Freezers Experts
ZJ Limited
ZJ Limited
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
View Most Popular
Frigidaire Freezers
  • Frigidaire Freezers
Most Popular Question
s electrical short circuit inside
  • Freezers
