20 Most Recent Frigidaire 12 cu. ft. / 340 liter Upright Freezer FFU12C2A Questions & Answers
besides hitting the compressor with a hammer. unplug and lay on its side for 2 hours then upright for 24 hours plug back in. Never ever unplug a freezer
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Frigidaire 12... | Answered on Oct 06, 2017
Thank you for your post, Paul!
I understand you would like to replace the temperature control on your Frigidaire freezer. I was unable to locate any detailed instructions on how to do so. In order to access the control you would need to disassemble your freezer and this is not a simple DIY job. I would recommend having a professional technician out to perform a proper diagnosis and repair. This will help you to avoid any unnecessary part purchases and personal injury. I hope this information is helpful to you. -Matt
Frigidaire 12... | Answered on May 18, 2015
The unit may be stuck in a defrost mode.Check the timer.Turn the knob to take it out of defrost.The unit will start up when this is done and the defrost timer is the culprit.
Frigidaire 12... | Answered on May 30, 2014
Carolyn,
If this is a commercial freezer we offer a custom made gasket option. It's a simple process at coolergaskets.com
Step 1: visit our custom made gaskets page HERE and identify the gasket profile material that best matches your existing gaskets.
Note: If you have a hard time with this we offer a $1 gasket sample ring.
Step 2: Input the outside edge dimensions you need your gasket to be (length and width) and how many sides it has (3 sided gaskets are most common for walk-in coolers/freezers, You will want precise measurements. Here's our " How to measure your gasket" video.
Step 3: Select the quantity you want and add that gasket to your cart where you will be able to proceed to check out there. Then relax because your gasket is in good hands!
Frigidaire 12... | Answered on Dec 13, 2013
usually the higher the number the colder the temperature
Frigidaire 12... | Answered on Nov 06, 2013
The power coming into the fridge goes to the thermostat and when it's time for cooling the thermostat tells the compressor and other components to come on so it has to be the thermostat..Does the light insinde the fridge work? If so i would replace the thermostat and it should fix the problem!!!
Frigidaire 12... | Answered on Aug 22, 2013
When you say not working, do you men the bin control arm is broken off or the water supply is off to the ice maker. Give me. Little more info s to specifics o I cn help better.
Frigidaire 12... | Answered on Feb 06, 2013
almost certainly a problem with the defrost timer - just replace complete. doesn't matter what position you set timer to when replaced
Unplug the unit, Remove bracket holding the Cap. Then remove the terminals. Replace with new Cap and tie bracket back down...
Frigidaire 12... | Answered on Aug 22, 2012
refrigerators have a door alarm that alerts users when the door is left open.
The alert is a beeping noise that is made when the door is left open more than 60 seconds.
Though the alert was created in an attempt to help users save on electricity, many find it annoying.
Two methods are available to stop the beeping /alarm in your refrigerator.
Instructions bellow
  1. Check the doors on your refrigerator. If the doors were left open, the alarm starts beeping. Closing the door will stop the alarm.
  2. 2 Press and hold the "Lock/Alarm" button on the control panel until the indicator light turns off. This shuts off the door alarm and it will not beep if the refrigerator doors are left ope.
  3. Reactivate the alarm by pressing and holding the "Lock/Alarm" button until the indicator light turns on.
Thanks for using fixya.
Frigidaire 12... | Answered on Aug 06, 2012
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Frigidaire 12... | Answered on Jul 24, 2011
Freezer alarms indicate two things: The door is not closed correctly; The temperature is warmer than -12 degrees.
The alarm can be visual ( red warning light), in either case it can happen if you have just filled your freezer with loads of fresh unfrozen food, however the alarm should self cancel after approx 20 mins as the freezer chills the fresh food and the warm air, down. A persistent alarm should be investigated by a fridge engineer as soon as possible, any food defrosting below -8 degrees is definitely suspect as far as refreezing is concerned. Where a failed thermostat causes the alarm the food will totally defrost, where a gas system is inefficient it's possible to have an intermittent alarm. The freezer should maintain a temperature between 0-5 degrees and if it gets above 15 degrees, the alarm will sound. This could be a thermostat problem, if it's keeping the compressor off too long. If the compressor is not running and it's warm inside the cabinet, turn the thermostat to a colder setting. If the compressor comes on, the thermostat will need to be replaced. If the compressor still won't run, check if it's hot but be careful. If the compressor is hot, the problem can be with the start kit or the compressor has failed. Another possibility is if the compressor is running but there is not a full frost pattern on all the shelves, it indicates problem in the seal system. Whichever cause happens, it will need a thorough checkup and repair by an engineer.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Frigidaire 12... | Answered on May 28, 2011
do not rely on the "settings" for the freezer,they are a guide ONLY.use a proper thermometer to get it to minus 18C.
Frigidaire 12... | Answered on Oct 04, 2010
dear sir /madam
if your freezer,s electrical safety switch is tripped of it,s an electrical problem it can be possible your compressor getting extra load and there is some electrical trouble please contact to your freezer maintenance personnel for further action.
hope answer the question
thank you
please vote!
Frigidaire 12... | Answered on Sep 15, 2010
dear sir/madam
i think if all electrical device is working good then there can be possible low gas problem, for further action or refill the gas please contact your maintenance personnel.
thank you
please vote!
Frigidaire 12... | Answered on Sep 14, 2010
Frigidaire 12 cu. ft. / 340 liter Upright Freezer FFU12C2A Logo
39 questions posted
Top Frigidaire Freezers Experts
AJMAL KHAN
Dennis Boxerman
Bruce Denton
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
View Most Popular
Frigidaire Freezers
  • Frigidaire Freezers
Most Popular Question
frigidaire up right freezer used make
  • Freezers
