20 Most Recent
Sony RMV210 Remote Control Questions & Answers
Remote control follow progrmming instuction Remote doesn't work
Make a code search process. Visit this site for more details. Type in the site name
"Electro-help" either Google or Yahoo
search box [
not
in the address bar of your browser], and click search. It is an electronic equipments service help
site. All details you want are
there.
Note the position of
hyphen in between words in site name, when you type it in.
The site will appear as it is in
web; subtitled as service help to electronic home entertainement equipments.
Pull up older posts.
You can get all details.
Check associated ads too.
Sometimes, it might help you.
Codes for norcent tv
go to www.fitness.manualsonline.com or www. remotecodelist.comfor freedownload.sincerely. God bless you
I lost the papers that
Here ya go. Heres some brief instructions and a link to sony for the codes and full instructions
Follow these steps to program the remote control.
- Turn on the component to be programmed.
- On the remote control, press and hold the SET button until the
SET indicator lights up.
- Press the appropriate component select button for the component being set
up.
- Using the number pad, enter the component's manufacturer code.
NOTE: If more than one code number is listed for the manufacturer,
repeat the procedure, entering one code at a time until you find one that
works.
- Press the ENTER button.
- Point the remote control at the component and press the POWER
button.
NOTES:
- If none of the codes listed for the manufacturer work, it may be necessary
to try codes listed for other manufacturers or perform a search for the correct
code. Consult the Operating Instructions provided with the remote control for
steps on searching for the correct code.
- If a new code number is entered, the code number previously entered will be
erased.
- When the batteries are replaced, the programmed codes may be erased. It may
be necessary to reprogram the remote after replacing the batteries.
- The operation of a combination deck of any kind is not guaranteed.
- Some product functions may not be able to be controlled by the remote
control. Use the remote control provided with the component.
- In some rare cases, you may not be able to operate your non-Sony equipment
with the supplied remote control. This is because your equipment may use a code
that is not provided with this remote control. In this case, please use the
equipment's own remote control.
- If programming fails, it may be necessary to reset the remote control. To
reset the remote control, remove the batteries and press each button on the
remote control twice.
go here for more information
http://esupport.sony.com/US/perl/model-remote.pl?mdl=RMV210
Sony Rmv210 Remote Control
The code is 8083, press SET until the light comes on, enter the four digit code, press ENTER, light will go off.....hope this was helpful....
How do i program this remote to my time warner
Time Warner is most likely made by another company and they are not listed on the programming documentation. You can try looking online to see who makes your Time Warner box. You should be able to program the manufacture off of the program list. The universal code for this remote is 8107 and 8108 which may work as well. To program the remote press set and the light next to set will start flashing. Press the desired component button ex(TV , VCR, CBL, DVD). Next enter the code 8107 and press ENTER. The set light should no longer be flashing. If 8107 does not work try 8108 using the above info.
I have lost my paperwork and forgot how to program my remote
Turn the device on that you want to program. Press and hold
Set for 2 seconds. When the light is on, press the device button you want to set. Then press the Channel + or - and press power after. When the device turns off, press enter and your code is saved. If all functions do not work after this, repeat the process until you get the right one.
I need the V210 remote control manual
Here is the site where you can download a pdf of the manual
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=sony&dv=universalremote&md=rmav2000&kw=&st=&ar=&dt=&so=&pg=1&file=others/sony/rmav2000-manual.zip
Code
hi alex,
there are diff codes for diff brands of TV, may I know what is the brand and mode of your TV?
Here is an example.
For Sylvania Televisions:
According to the manual it is 8083.
You can download the manual on this link. You don't need to put in your email address to download, I didn't.
http://www.retrevo.com/support/Sony-RM-V210-Universal-Remotes-manual/id/7048bh151/t/2/Just click on get manual then follow the download instructions minusyour email, but you have to put in the numbers just above startdownload. These number keep computers from automatically downloadingand crashing sites.
regards.
I lost the manual
You will find the manual here>
http://esupport.sony.com/US/perl/model-documents.pl?mdl=RMV210&LOC=3
Please vote if I helped you.
