20 Most Recent
Viking 48 in Built In Professional Integrated Side by Side Refrigerator - VISB483SS Questions & Answers
How do I clean the
http://www.vikingrange.com/MEDIA_CustomProductCatalog/m3020004_F20603.pdf
Download and turn to page 33
Beeps that it is warm
bad weld unlikely part with leak that should have been replaced more likley
freezer way to warm sounds like the charge they put in took about 6 months to leak out the hole that was never repaired
need a servicer
Viking 48 leaking water
There is a drain pan heater unless mfr before 2005. Call Viking parts for that heater kit and eliminate that issue . 8004889868
DFSB483 Side by Side Inlay Viking Refrigerator not cooling
The unit should not need to be pulled out diagnose it.
At the bottom on the rear inside wall of the Freezer can you see any signs of frost build up?
If there is then it is more than likely the defrost terminator
When you open the freezer door can you hear the fan blowing in the freezer?
If not then the Evaporator fan could,be bad and need replacing.
If there is no frost and the fan is running, try turning the unit off and then back on, the power off switch is accessed by removing the center grill of the top grill. There are 2 switchs in this compartment. If you flick the switch and the lights stay on this is the wrong switch, flick it back and find the other switch, power the unit off and then back on. What you should here is first the fans come on followed by the compressor, it will take about 6mins for this to happen. If the compressor is running and you have no cooling then you have a sealed system issue and you ned to get a certified personnel to come and make the repair.
DISPLAY LIGHTS NOT WORKING
Have you tried the display on button on the keyboard, it is situated at the far right of the keyboard in the refrigerator side.
