20 Most Recent
Peavey PV14 14-Ch Mixer/USB Interface W/ Dsp Fx Questions & Answers
Peavey PV-20 monitor sends
As long as you don't need stereo at FOH, then all you need is the left(mono) output from the cd player connected to any available Line mono input on your mixer. RCA or balanced 1/4"TRS. Then use monitor sends level as desired. If you need stereo anywhere in the chain, then its a whole different matter.
Peavey fx32 factory reset password
Looking at the manual, the fx32 is unsecured until someone selects a password, so you'll have to ask the previous owner, or try some obvious defaults like 1234.
Try peavey.com - someone else asked this question and got sent an email.
I'm using my mixer with
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it hope this helps
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select enable windows 7
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
I am trying to go
On your computer you can use the 1/4" stereo input jack. Not sure of your options on the 680s, but any output (1/4" or rca) would work. Refer to your manual, or just check the jacks to see which ones you want to use.
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired an
employment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut.
They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
Solitaire master has a hang
clarify pi please. if you meant pi to mean main screen picture, you probably have used up your free time on this program.
Is there any one here know B**** food equipment? I have question about this company?
As you are Anonymous, it would seem like this is a veiled advert to get the company name promoted.The company is in British Columbia, Canada. What is your concern? I am in Ontario and have had a 50 years career in catering.Finding them is easy, reviews are goodRahmalek "Very good service, best prices in town."Mikey "Great customer service, reasonable service fees and on time all the time."salek "Great experience working with B***** FOOD equipment. excellent customer service."..
