20 Most Recent HTC Qtek 9100 Smartphone Questions & Answers
It's locked to Network call the You can get the unlock code from Network provider.or get the decode code from Online site
HTC Qtek 9100... | Answered on Aug 09, 2011
to unlock the first one you will need the imei to get this you need to dial *#06# in the dialing pad it will display a 15-17 digit code send it to anarchy1991@hotmail.co.uk and i shall try to find your unlocking code and as for the second i suggest using google translate to translate the menu and continue to translate through the menus till you find the translate options if there is any problems email me and i will see what i can do
HTC Qtek 9100... | Answered on Mar 16, 2011
This is actually a common problem, and is likely mentioned in the user manual.
Click on the start box, goto settings. Click on the Connections Tab. Click on USB to PC. Uncheck the "Enable Advanced Network Functionality" option. Reset (soft reset, not the hard data wiping reset), and try to connect again.
Many PDAs running Windows Mobile 6.x are afflicted by this, but nobody seems to know why.
HTC Qtek 9100... | Answered on Aug 20, 2010
my phone is in german i have followed the normal process to change into but its just not working what shoul i do, its not a decoding problem either,
HTC Qtek 9100... | Answered on Jul 14, 2010
que quieres decir com flexear?????????
HTC Qtek 9100... | Answered on May 08, 2010
yes you can change it via editted rom file with hex editor change it GER to ENG
HTC Qtek 9100... | Answered on Dec 15, 2009
your qtek 9100 is also known as Wizard, u can visit http://forum.xda-developers.com/ and download the required os or ungraded version of WM.
HTC Qtek 9100... | Answered on Dec 12, 2009
pls first confirm the charger is working or not and then kindly leave the pda for like 2 hours on charge it will start charging , when u store these devices for longer period kindly fully charge the battery and then store , when battery drains during non use it drops to a certain level from where it might come back or might not , pls leave the battery on charge for like 2 or 3 hours first and then u will see charging signs or light
pls rate me well !
HTC Qtek 9100... | Answered on May 17, 2009
Use the stylus to lightly press and hold the RESET button on
the left side of your device. The device restarts and displays the
Today screen.
09def71.jpg Warning! Always turn off your device before performing a soft reset or
installing/replacing the battery and SIM card.
To perform a hard reset
1. Press and hold the Comm Manager button and Voice Command
button on the device. At the same time, use the stylus to lightly
press the RESET button.
2. Keep the Comm Manager button and Voice Command button
pressed, and the following message will appear on the screen:
3. Release the two buttons, and press the Send button to perform a
hard reset.
HTC Qtek 9100... | Answered on Jul 02, 2008
HTC Touch Diamond you need to provide IMEI number (15 digits unique number). It can be found by dialing *#06# as a phone number, as well as by checking in the phone settings of your device.This service can unlock all HTC models, it does not matter if the network comes from Europe, USA or any other place (excluding list of unsupported networks), it can be unlocked on our website.
Please make sure that your HTC Touch Diamond asks for an unlock code, when you insert a simcard from a different network.
You can use any of the provides services, old, new, newest database it doesn't matter.
HTC Computers &... | Answered on Aug 13, 2019
HTC Qtek 9100 Smartphone Logo
28 questions posted
Popular Products
Top HTC Computers & Internet Experts
robert roberts
Tom Chichester
JonSnell Electronic
JonSnell Electronic
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Qtek HTC
  • Qtek HTC
Most Popular Question
change english language
  • Computers & Internet
