20 Most Recent
Apple Mac Mini Desktop Questions & Answers
My Mac mini is very slow how can i speed it up?
First, you have a complete knowledge about your system.
try to up-to-date your system.
check you CPU load time to time.
remove unnecessary process while working through Task Manager.
check your hardware
check for virus through antivirus
and more activities for full analysis of your system. if need more help follow
Mac Support .
Help Boot Camp Partition Resize
Free download
Stellar Partition Manager V3.0 and make a bootable usb with which you can boot your Mac and resize Boot Camp partition with the available free spaces. This software works on HFS, NTFS, FAT and EXFAT drives. Except EXFAT it resizes all other file systems.
I bought an old Mac Mini Intel Core 2 Duo, 2 GB Hard Drive, OS X Yosemite, with serial # C07CS2TPDD6H. What adapter cord could I use to connect it to an iBox C1752, TFT LCD Monitor?
That Mac has a hdmi port and a mini display port. The monitor has a saga port. So ether a hdmi-svga. Or miniDisplay port-svga.
Any usb keyboard will work. So any Mac keyboard newer than 12 years should be good, and newer pic keyboards will work. Beware of older keyboards that have round plugs. On macs these were ADB ports. On PC's, they used PS2 (ADB, ps2, usb are all different, you want the flat rectangle USB)
U.S. pc keyboards also have two modifier keys wired different than the U.S. Mac keyboards, but this can be adjusted in the system preferences. Can't say for non U.S. KBs. They are the windows/alt keys. Vs Opt/Command keys. That is, if you are soused to using a Mac, the key that is closest to the spacebar (command key) is applied by the second key over rather than the first. Again, this can be modified in the Sys Prefs.
Macintosh aoc monitor refresh rate
Europe has different power supply parameters than the USA, Obviously you discovered the voltage difference, hence the transformer, but the USA sends AC voltage at 60 cycles per second while most of Europe is at 50 cycles. You need a converter, not a transformer, if your monitor is capable, you may be able to set it to operate on the different frequency from display settings, or the monitors internal menu
Was not able to download from the ptp app to open
you mite have to put on a flash drive to open the file, when in the mac program i dont think you just open an app. if you have no flash drive do you have micro sd card you could put the file on than open that file.
if not any of thous than sending wifi to mini may work
How do I install a newer version of pages. When I download an attachment the computer says that I need a newer version of pages.
I might likely be able to help you but need a few 'back & forth' questions answered to do so. Some questions 'seemingly simple' but I don't know your level of knowledge so forgive me in advance:
- What is your operating system? (go to the apple , upper far left to first drop down - "About this mac")
- What browser are you using?
- What are you downloading that made you write? Is it everything you download that you have this issue with?
If you write back, I expect to be here to follow through & help you to find some answers.
Mac os 9 download
Check the system requirements that need 64-bit, Intel-based Macs currently running Mac OS X 10.6.7 Snow Leopard or higher, with 8GB of free disk space for installation. If need more help for any update
Apple and Mac Technical Support .
How do i erase all my personal data on my mac mini?
That depends on what operating system you have. If it's 10.6.8 or older, you need the operating system install discs that came with your computer. Just put it in and restart the computer. When you here the start up chime, press and hold the C key to boot from disc. Then in the utilities bar on the top, select disk utility and then the top left hard drive icon in the side bar do the disk utility application. Go to the erase option on the right portion of the screen and make sure the erase option says MAC OS JOURNALED and click erase. That wil remove all data off of the hard drive including the operating system. After that is done, you can reinstall the OS with the disks.
if your OS is newer than 10.6.8, hold option after the apple start up chime, this will let you select bootable drives that the computer detects, there should be a recovery partion, select that and repeat the steps in disk utility I mentioned above. If you need further help, I’m available over the phone at
https://www.6ya.com/expert/erik_3934b541f17c4e99
Track pad will not scroll down on my Mac mini
Let's try this:
1. Click on the Apple logo on the top left corner
2. Choose System Preferences...
3. Click on Trackpad
4. Select Scroll & Zoom
5. Make the selection the way you like it
Let me know if this fixes your problem or we need to look for another solution.
Desktop background doesn't show
I get this too. (Love using the solid blue background)
1. Check if there are any other users logged in on the Mac.
2. Log off all the users including yourself
3. Log in only on your user account and change the background
If that doesn't work, restart first and repeat.
If even that doesn't work, change to another solid background first and then change it back to the picture.
