20 Most Recent Seagate 3TB Expansion External Desktop USB 3.0 Hard Drive Questions & Answers
4answers
Manual for model no. SRD00F2 Seagate 3TB expansion drive
doesn't seem to work in Windows 7
6/5/2019 12:34:52 PM • Seagate 3TB... • Answered on Jun 05, 2019
Does the Seagate SRD00F2 have a power light?
http://www.seagate.com/files/staticfiles/support/seagate_external/Seagate_External_Desktop_Drv_QSG.pdf
2/21/2015 10:45:17 AM • Seagate 3TB... • Answered on Feb 21, 2015
Computer doesn't recognize hard drive
Is the drive greater than 2TB and you are using a 32-bit operating system? If the drive is greater than 2TB, you need a 64-bit operating system to be able to access it as a single drive. Right click on My Computer. If it doesn't say, it is probably a 32-bit operating system.
12/17/2014 12:30:01 AM • Seagate 3TB... • Answered on Dec 17, 2014
How do I retrieve my contacts off the external and put them into a new email account?
look for ".PST" files
9/18/2014 1:42:05 AM • Seagate 3TB... • Answered on Sep 18, 2014
Segate SRD00F2
Usually indicates the HDD has died
11/27/2013 4:44:07 PM • Seagate 3TB... • Answered on Nov 27, 2013
Beeping Sound and not working
Stick it in the freezer for a few hours then try. It may only work for 5-10 minutes at a time so get as much off of it as you can. Also, contact Seagate and check if it's still under warranty. If so, ask them to RMA it.
7/13/2013 4:14:44 PM • Seagate 3TB... • Answered on Jul 13, 2013
Unsupported usb
Windows has a 2 TB MBR limit. So, I expect the TV does as well. What that is?You need to ready new hard drives by formatting prior to use, and in your case partition as well.
4/16/2013 10:29:25 PM • Seagate 3TB... • Answered on Apr 16, 2013
How do I break down and partition the drive ??
Type diskmgmt.msc in search. There you will see all the drive, but may be already partitioned and or unallocated. A wizard may auto load if truly clean, but you can erase, create, delete, format, and partition just by right clicking.2TB limit with 4 partitions on a single drive! Make then basic.
1/30/2013 12:05:06 AM • Seagate 3TB... • Answered on Jan 30, 2013
Hi I have a 3tb ext harddrive - the led is flashing and my computer won't read the drive files
A single MBR physical drive is limited to 2TB in Windows. This is a common setup. You will need to break down and partition the drive in order to use it.
1/29/2013 12:45:01 AM • Seagate 3TB... • Answered on Jan 29, 2013
How to delete backup on my seagate backup plus slim
Detailed steps to manage backup disk space
To delete old backups on Windows 7/8/10 using AOMEI Backupper, you need to set up Backup Scheme during the process of creating a backup. When your backup versions exceed the number of backup images files, AOMEI Backupper will delete older backup automatically. Step 1: Connect your Seagate Backup Plus drive or Central hard drive to the computer and make sure it can be detected by your computer. Step 2: Download AOMEI Backupper Professional, install and launch it. Step 3: Click Backup and File Backup subsequently Step 4: Choose the files and folders you want to backup and pitch on a path for it. Then, Click Schedule option and select Schedule Settingsfrom the following window. Step 5: Click Scheme option, tick Enable Disk Space Management and select whatever Scheme you need from the drop-down menu. Then, back to the main page of File Backup and click Start Backup. After that, your older backup will be deleted automatically when your file backups exceed the versions of backup image files.
2/26/2024 7:21:41 AM • Seagate... • Answered on Feb 26, 2024
Ive got a 8tb seagate its got a blinking blue light and wont connect to my Pc? Any help?
Did you initialize it?
7/3/2023 8:38:03 AM • Seagate... • Answered on Jul 03, 2023
Seagate Portable Hard drive 4TB, part number 2N1AP6-500
Hi, Please put your computer into safe mode before attempting to connect to the hard drive again. Safe mode turns some feature off when activated so whatever program is forcing the shutdown might have be paused when connecting to the external hard drive. Also, try connecting the hard drive to a non-laptop intermediary device and then connecting that device to your computer and attempting to access the hard drive folder within the intermediary drive. Thank you.
11/11/2022 2:11:28 AM • Seagate... • Answered on Nov 11, 2022
2answers
How to recover data from a dead Seagate external hard drive on my Computer?
Should be careful with the data file deposited on the Seagate external hard drive. your Seagate external hard drive might be dead or corrupted. In this situation, you might need to rely on data recovery software to get back data and files on the dead Seagate external hard drive. So you can rely on data recovery software to get back lost data and files when the Seagate external hard drive is dead and inaccessible. Data recovery hong kong technician provide the Ontrack EasyRecovery data recovery services are able to recover data and files from accidentally formatting, corruption, virus attack, dead, system crash under different situations Seagate external hard drive on Windows Computer. This data recovery software allows you to deep scan the dead Seagate external hard drive so as to find out almost all lost files with original quality in a short time. You can also rely on this software to recover files from dead/damaged Seagate external hard drive. The software supports to get more recover: Seagate External hard drive, data file, documents, PDF, Excel, photos, music, and videos any HFS, HFS, FAT, ExFAT, and NTFS format based data and file and more. It will recover data and file from all external storage devices that can be recognized by your Windows PC Computer/Laptop. Hope this helps you get to recover all your lost data and files from your dead Seagate External hard drive.
10/8/2021 1:02:33 PM • Seagate... • Answered on Oct 08, 2021
What enclosure is compatible with a Seagate Barracuda 7200.7 SATA Drive?
TRY LOOKING FOR TIGERDIRECT .COM THEY SELL STUFF FOR COMPUTERS
10/3/2021 8:21:41 PM • Seagate... • Answered on Oct 03, 2021
5answers
Need restore my RAW file system back to NTFS without losing any hard drive files?
There are two options for you to get your drive stuffs back right now: 1). Do not format this RAW file system external hard drive temporarily and plunge it to your PC. And then, choose and apply RAW external hard drive data recovery software to scan this drive and find your preferred drive files back as many as possible. 2). Directly consult some professional data recovery services from some data recovery companies or agencies. In the future, remember to save copies of everything important on at least two devices in case of any similar data loss issues.
1/5/2021 2:43:04 PM • Seagate... • Answered on Jan 05, 2021
I have seagate plugged in and attached to my computer. I downloaded the program but I get the message connect a dashboard enhanced drive to activate features ??
Can you please provide more detail on the program you are downloading, the model of drive, and model of computer?On the face of it, the program seems to be saying it is not compatible with the model of drive you have plugged in, or that the drive has been reformatted in a way that is not compatible. Does the drive show up in the File Explorer / Finder of the machine?after comment : ok, if you can drag and drop files onto it, then That means it is operational, and recognized by the system. The next question is why you can’t install the Seagate Desktop software. Where did you get the software from? Try going to Seagate Support and looking up your drive model, and doing a fresh download of the software they have for that model. Alternatively, there are other backup software packages available, Acronis, Aoemi, EaseUS, and others. You can find reliable downloads of utility software at downloads.com (CNET) or look for reviews from PcWorld or PCMagazine for their recommendations of the best paid and free backup software
10/20/2019 9:49:12 PM • Seagate... • Answered on Oct 20, 2019
Seagate 3TB Expansion External Desktop USB 3.0 Hard Drive Logo
22 questions posted
Top Seagate Computers & Internet Experts
Sean Wright
Sean Wright
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Seagate Computers & Internet
Most Popular Question
manual model no srd00f2 seagate 3tb
  • Computers & Internet
