20 Most Recent
HP Compaq Presario SR5350F Desktop PC Intel Pentium Dual Core Desktop Processor E2160, 2GB RAM, 360GB Questions & Answers
Requirements for building up a pentium 2
I'm not sure what you want to do, but you will find that you are going to be severely limited in what you can upgrade on the mainboard. This is because the mainboard was built specifically for HP/Compaq and as such the BIOS is not as generic as with an brand name mainboard that you can buy. Thus, you will find that you may have fewer CPU and RAM upgrade options. There is a good chance that you can probably expand the RAM capacity above 2GB. Remember though, that if you are only running a 32-bit Operating System, you will be limited to 3GB of accessible RAM regardless of the amount installed. Realistically, you probably won't be very happy with whatever performance gain(s) you can get for the money you will spend on this machine.
That said, most newer HP/Compaq desktops utilize a fairly standard ATX case. This allows you the possibility to install a completely new mainboard/CPU/RAM to gain massive performace benefits for the money spent. You may even be able to continue to use the existing hard drive and CD/DVD drive if they are SATA rather than PATA interface.
3/6/2015 12:24:41 PM •
HP Compaq...
Answered
on Mar 06, 2015
Should i download google chrome update from getsoftfree.com
You should avoid getsoftfree.com, as it may be a vector for malware. See...
http://www.scamvoid.com/check/getsoftfree.com You may have a virus, malware, adware, a browser hijacker, or pups (potentially unwanted programs). A. If your computer will boot and you can operate it ok... Download and install Malwarebytes and Superantispyware (Note: If you can\'t do the download on your machine, do it on a friend\'s, put them on a thumb drive, and install them from it). Then scan your computer with each program, and quarantine anything found. B. If your computer won\'t boot, or can\'t operate properly after boot... Tap F8 when you are booting, select "Safe Mode With Networking". Download and install Malwarebytes and Superantispyware (Note: If you can\'t do the download on your machine, do it on a friend\'s, put them on a thumb drive, and install them from it). Then scan your computer with each program, and quarantine anything found. C. If this process finds malware, to keep stuff like that from coming back, I recommend you get the paid version of Malwarebytes.Good luckG
2/15/2015 12:13:54 AM •
HP Compaq...
Answered
on Feb 15, 2015
Do i want to run this file published by air software type appl. downloads/google chrome update
If you have visited getsoftfree.com, you may have a virus, malware, adware, a browser hijacker, or pups (potentially unwanted programs). A. If your computer will boot and you can operate it ok... Download and install Malwarebytes and Superantispyware (Note: If you can\'t do the download on your machine, do it on a friend\'s, put them on a thumb drive, and install them from it). Then scan your computer with each program, and quarantine anything found. B. If your computer won\'t boot, or can\'t operate properly after boot... Tap F8 when you are booting, select "Safe Mode With Networking". Download and install Malwarebytes and Superantispyware (Note: If you can\'t do the download on your machine, do it on a friend\'s, put them on a thumb drive, and install them from it). Then scan your computer with each program, and quarantine anything found. C. If this process finds malware, to keep stuff like that from coming back, I recommend you get the paid version of Malwarebytes.Good luck
7/30/2014 9:41:52 PM •
HP Compaq...
Answered
on Jul 30, 2014
Is it safe to install google chrome update 1.exe
If you got anything from getsoftfree.com, you may have a virus, malware, adware, a browser hijacker, or pups (potentially unwanted programs). A. If your computer will boot and you can operate it ok... Download and install Malwarebytes and Superantispyware (Note: If you can\'t do the download on your machine, do it on a friend\'s, put them on a thumb drive, and install them from it). Then scan your computer with each program, and quarantine anything found. B. If your computer won\'t boot, or can\'t operate properly after boot... Tap F8 when you are booting, select "Safe Mode With Networking". Download and install Malwarebytes and Superantispyware (Note: If you can\'t do the download on your machine, do it on a friend\'s, put them on a thumb drive, and install them from it). Then scan your computer with each program, and quarantine anything found. C. If this process finds malware, to keep stuff like that from coming back, I recommend you get the paid version of Malwarebytes.Good luck
7/30/2014 9:39:36 PM •
HP Compaq...
Answered
on Jul 30, 2014
Fan runs loud
You can try to update the BIOS - that used to correct the issue when I supported these a few years ago. Does it run loud in Safe Mode as well? If so, chances are the fan will require replacing.
Regards,
M
1/5/2014 9:30:02 PM •
HP Compaq...
Answered
on Jan 05, 2014
How much ram can i upgrade my compaq presario? I
One good and easy way to find out for sure how much RAM your computer can hold is to go to WWW.CRUCIAL.COM and run their SCAN MY COMPUTER feature. This handy utility will scan your hardware configuration and tell you exactly how much RAM you currently have installed and what type it is. It will also tell you how many RAM slots are fitted on your motherboard and what the maximum memory capacity is for each slot and the total capacity for that motherboard. If your computer does have room to add more RAM, it will provide you with specific recommendations as to exactly what type and size of RAM stick to get to maximize the memory capacity and performance of your computer.I hope that was helpful to you, good luck.Joe.
11/5/2011 3:43:50 PM •
HP Compaq...
Answered
on Nov 05, 2011
I cant use IE or
download google crome n uninstall all othere web browsers.or tell some1 to mail u the files for chrome.
7/7/2011 12:55:52 PM •
HP Compaq...
Answered
on Jul 07, 2011
I need NIC drivers for
Realtek LAN Driver
This is the Type which is installed on your PC
Realtek RTL8169/8110 Family PCI Gigabit Ethernet NICRealtek RTL8168/8111 Family PCI-E Gigabit Ethernet NICRealtek RTL8101 Family PCI-E Fast Ethernet NICFor Vista 32-bit
Click Here to Download the driver
For Vista 64-bit
Click Here These links are From Official Compaq site.Unfortunately there are is no download option for XP and Windows 7 on Compaq site.
so use the below link directly from Realtek
Click Here
Try this first if this driver don't work use
this it should get installed- Realtek Official site Choose Windows and Download the appropriate one according to your operating system. Here you have for all versions of windows.
2/4/2011 11:53:26 PM •
HP Compaq...
Answered
on Feb 04, 2011
How much would it cost to run this computer for 24
Wattage
is simply calculated by multiplying voltage by amperage. Look on the
back of your system, and it will say how many amps the system uses.
Often, it will also provide the wattage. For instance, the back of a
ViewSonic E220 is 2.5A at 120V - ~300 Watts/Hr. An average rate is 10
cents per kilowatt hour, or 3 cents per hour to leave your monitor on.
or 72 cents per day.
A computer system can use between 150 and 600 or more watts per hour. Together, it could cost between $20 and $60 a month
Read more: Click Here
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
1/6/2011 10:17:05 PM •
HP Compaq...
Answered
on Jan 06, 2011
